manchester decode
Goto page Previous  1, 2, 3 ... 16, 17, 18, 19, 20  Next
bulut_01
PostPosted: Sun Feb 09, 2025 12:01 pm     Reply with quote
PrinceNai wrote:
you must have thought we were amateurs
No, I don't :-). But since you are a bit on the stiff side with the information, I must ask. Must is a bit strong word, at this point I simply want to, because it really interests me. You mentioned all zeroes in the buffer. Fine. Does your code ever reach the point where it must write a one there? Does it increment counters, at least two of them? How can I know that without asking you? I have no idea about the equipment you use, save for the analyzer and the programming software. What are you debugging with? How? You never say: I did this, I tried that. Result is this. I know that my setup works. And it didn't work off the bat, far from it. But I went step by step. There is a diode blinking, so I know my PIC is alive. There was a breakpoint sitting in the first two states so I knew I could catch the preamble every time. Only after that I went to the decoding part. Drew a diagram of one byte and worked out the timings. Catching my own errors, both in code and in mental process. I prove to myself every time that the code does what you write, not what you think it should do. Those two things are seldom the same at the start.
Anyway, I was tinkering with the code since the version posted previously, so this is the last version:
Receiving part:
#include <18F46K22.h>
#device ADC=10
#FUSES NOPUT
#device ICD=TRUE
#use delay(internal = 32000000)
/////////////////////////// DEFINES /////////////////////////////////
#define NUMBER_OF_BYTES 7                                            // number of DECODED bytes to receive
#define TE 640                                                       // duration of one bit in us, change as needed
#define PREAMBLE_MAX_TIME 8*TE
#define PREAMBLE_MIN_TIME 6*TE                                       // we expect a 7 bit preamble, make some room for clock error
#define TRANSITION_MIN_TIME 1.5*TE                                   // same here when sampling
#define TRANSITION_MAX_TIME 2.5*TE
////////////////////////// VARIABLES ////////////////////////////////
char DecodedInputData[10];                                           // buffer for decoded data
char CurrentByte = 0;
int8 InputByteCounter = 0;                                           // keeps track about which byte we are filling in
int8 BitPosition = 0;                                                // bit position of the incoming data
int8 Have_Data = 0;                                                  // flag to inform main data was received and decoded
// switch
enum {GotRisingEdge = 1, GotFallingEdge, SampleData};                // state machine switch
int8 DecodeSwitch = GotRisingEdge;
// Timer
int16 TimerValue;
int8 TMR0_Overflow = 0;                                              // how many times TMR0 has overflowed
////////////////////////// FUNCTIONS ////////////////////////////////
#bit INTDEG  = getenv("BIT:INTCON2.INTEDG0")                         // declare edge selection bit for INT_EXT. INTDEG is a generic name (some PIC's have more than one of those registers,
void ToggleIntEdge (void){                                           // 18f46k22 has INTDEG0, for example) for external interrupt on Pin_B0. Change this for the PIC you use
   if(INTDEG == 1){                                                  // check which edge is currently selected
      INTDEG = 0;                                                    // activate interrupt on falling edge
   else{
      INTDEG = 1;                                                    // activate interrupt on rising edge
void ClearBuffer (void){
   DecodedInputData[0] = 0x00;                                       // lazy :-)
   DecodedInputData[1] = 0x00;
   DecodedInputData[2] = 0x00;
   DecodedInputData[3] = 0x00;                                       // lazy :-)
   DecodedInputData[4] = 0x00;
   DecodedInputData[5] = 0x00;
   DecodedInputData[6] = 0x00;
   DecodedInputData[7] = 0x00;
   DecodedInputData[8] = 0x00;
   DecodedInputData[9] = 0x00;
//////////////////////// END OF  FUNCTIONS //////////////////////////
//                        INTERRUPTS
#INT_TIMER0
void  TIMER0_isr(void)
   TMR0_Overflow++;                                                  // count timer TMR0_Overflows
#INT_EXT
void  EXT_isr(void)
   clear_interrupt(INT_EXT);                                         // clear interrupt, needed for this particular interrupt type or you come back straight away
//default handling, check if switch variable is out of usefull bounds
   if (DecodeSwitch < 1 || DecodeSwitch > 3)
//      printf("Default handling, testval is out of bounds, DecodeSwitch == %u\r\n", DecodeSwitch);
      continue;                                                      // Miss switch. The continue statement causes the next iteration of the enclosing loop(While, For, Do) to begin.
   switch (DecodeSwitch)                                             // state machine used to receive and decode Mancester encoded data
// wait for a rising edge on the input, this state also serves as a reset. Always come here with L_TO_H transition set (maybe not even needed)!
      case GotRisingEdge:                                            // we have a rising edge, could be start of the preamble
         set_timer0(0);                                              // reset timer
         TMR0_Overflow = 0;                                          // and various counters
         BitPosition = 0;
         CurrentByte = 0;
         Have_Data = 0;                                              // and flags
         ext_int_edge(0, H_TO_L);                                    // change direction of the interrupt to falling edge
         DecodeSwitch = GotFallingEdge;                              // and go to GotFallingEdge to see if we have a preamble
      case GotFallingEdge:                                           // we have a falling edge, pulse ended. Might be preamble.
         ext_int_edge(0, L_TO_H);                                    // prepare next interrupt on a rising edge
         TimerValue = get_timer0();                                  // check the time that elapsed between two interrupts
         if(TMR0_Overflow == 0 && TimerValue > PREAMBLE_MIN_TIME && TimerValue < PREAMBLE_MAX_TIME) {   // bingo, time is good, we have a preamble
            set_timer0(0);                                           // preset timer for next measurement
            TMR0_Overflow = 0;
            DecodeSwitch = SampleData;                               // and go sample the input
         else{                                                       // not good, pulse was either too short or too long for a preamble.
            DecodeSwitch = GotRisingEdge;                            // Reset state machine
// We are looking for a transition that in Mancester coding always exist in the middle of a symbol,
// so the sampling is done every 2TE. That can be on the first or second following interrupt,
// depending on whether two subsequent symbols have the same or different value.
// We are using TMR0 value to find if it is time to sample. If it is, sample the input and store
// to the correct location in the data buffer.
// The word symbol means a 2-bit pair that represents either a 1 or a 0.
      case SampleData:
         ToggleIntEdge();                                            // change the active edge of the interrupt for the next one,
        // because transition can be either 0-1 or 1-0, but hardly
        // 0-0 or 1-1
// If this interrupt occured in a time frame from 0,5*TE to 1,5*TE, this symbol has the same
// value as the previous, meanng that interrupt occured also at the start of the symbol, not only in the middle.
// So we need to wait for the next interrupt that will come at the middle of a symbol to actually sample data
// Time between two edges is correct, read input state. This test is intentionally put in the first place
// so it gets serviced first, since the timer is already running for the next symbol
         if(TMR0_Overflow == 0 && TimerValue >= TRANSITION_MIN_TIME && TimerValue <= TRANSITION_MAX_TIME){  // this is the one we are looking for, sample and store the data
            set_timer0(0);                                           // reset timer for the next symbol
// INVERT THE DECODING LOGIC AS NEEDED HERE!!!!! COMMENT THE WRONG IF OUT!!!! LIKE THIS WORKS FOR IEEE 802 CODING, 01 IS 1, 10 IS 0
//            if(input_state(pin_B0) == 0){
            if(input_state(pin_B0) == 1){
               bit_set(CurrentByte, 7 - BitPosition);                // Sample input. Set appropriate bit if needed, leave 0 otherwise
            BitPosition++;
            if(BitPosition > 7){                                     // one byte of data was received
               BitPosition = 0;
               DecodedInputData[InputByteCounter] = CurrentByte;     // store that data into the buffer
               CurrentByte = 0;                                      // prepare variable for next byte (all zeroes, since we are only setting the bits needed)
               InputByteCounter++;                                   // increment byte counter for a correct position in the buffer
               if (InputByteCounter == NUMBER_OF_BYTES){             // if all the bytes are in the buffer, reception is done
                  Have_Data = 1;                                     // we have data, signal that to main
                  DecodeSwitch = GotRisingEdge;                      // and reset state machine for the next reception
               }  // if byte counter
            }     // if bit position
         }        // end sampling
// time between two edges is too short for sampling, it may be transition between two symbols with the same value
         else if(TMR0_Overflow == 0 && TimerValue < TRANSITION_MIN_TIME){      // the transition came too soon for sampling, exit interrupt but leave
            delay_cycles(1);                                         // the timer running and stay in the same case
// time between two edges to long for a valid symbol, reset
         else{                                                       // time between two transitions was too long,
            DecodeSwitch = GotRisingEdge;                            // reset state machine
      }           // end case
   }              // end switch
}                 // end interrupt
//                       END OF INTERRUPTS
   ClearBuffer();                                                    // clear receiving buffer
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);                          // 65.535us, resolution 1us. RESOLUTION MUST BE 1us!!!!
   ext_int_edge(0,L_TO_H);
   enable_interrupts(INT_EXT);
      if(Have_Data == 1){
         Have_Data = 0;                                              // do something with data
16F1824 register not
PrinceNai
PostPosted: Sun Feb 09, 2025 12:17 pm     Reply with quote
It can't, that is where this bit is located on 18f46k22. I wrote in one of the previous posts that you'll have to find that bit for your PIC. Yours is in the OPTION_REG, bit 6. Page 176 of datasheet.
So: #bit INTDEG = getenv("BIT:OPTION_REG.INTEDG")
I just noticed there is a typo in my program here (should be #bit INTEDG). Use this the way it is written here.
PostPosted: Sun Feb 09, 2025 12:56 pm     Reply with quote
CURIOUS... I see ICD=TRUE....
Is there a possibility that that can cause problems ? I've never used it but know that building in 'debug' and trying to run in the Real World doesn't work.
PrinceNai
PostPosted: Sun Feb 09, 2025 1:07 pm     Reply with quote
Never had a problem or noticed any difference so far. I also never checked if the .hex is different with that option enabled. Did a quick build with it turned off now and the .hex size stays the same.
In this particular case the receiving PIC is in debug mode for testing purposes.
bulut_01
PostPosted: Sun Feb 09, 2025 2:47 pm     Reply with quote
What hardware do you use to debug? Pickit 3 or icd3
PrinceNai
PostPosted: Sun Feb 09, 2025 3:10 pm     Reply with quote
Pickit3.
Below is the comparison between two streams you sent, 44 and 55. Green portions were the same for both.
https://ibb.co/B2MpDfh0
bulut_01
PostPosted: Wed Feb 12, 2025 6:08 am     Reply with quote
PrinceNai wrote:
Pickit3.
Your code is not working. The reason is that all timers in 16f1824 are not overflowed by 1 us. When I debug, timer0 is overflowed by 32 us. You need to edit your code according to the timer overflow of 32 us.
PostPosted: Wed Feb 12, 2025 6:57 am     Reply with quote
Please post your latest code
bulut_01
PostPosted: Wed Feb 12, 2025 7:08 am     Reply with quote
PrinceNai
PostPosted: Wed Feb 12, 2025 7:47 am     Reply with quote
will not produce 1us Timer0 step with 32MHz clock. Check Timer0 setup in my code.
PostPosted: Wed Feb 12, 2025 8:03 am     Reply with quote
clock is 32Mhz
input to Timer0 is Fosc/4, so 32/4 = 8Mhz
Timer0 prescaler is '1' , so /2 = 4Mhz
1/4,000,000 = .00000025
not to sure how you calculate 32 useconds
bulut_01
PostPosted: Wed Feb 12, 2025 8:06 am     Reply with quote
Your code is exactly the same, where do I check?
bulut_01
PostPosted: Wed Feb 12, 2025 8:09 am     Reply with quote
16f1824 timer0 is 8 bit. you need 16 bit counter timer1 is 16 bit. 1 us overfloaw does not work
PostPosted: Wed Feb 12, 2025 8:15 am     Reply with quote
so you have to change to another timer !!!
you have timers 1, 2 4, 6 on the t PIC with 16 bit counters....
PrinceNai
PostPosted: Wed Feb 12, 2025 8:16 am     Reply with quote
Then use Timer1. Change all references from Timer0 to Timer1. Mind you, overflow isn't 1us. Timer increments by 1 in 1us. Overflow is 65ms
Page 17 of 20
