ratgod
Joined: 27 Jan 2006 Posts: 69 Location: Manchester, England
Posted: Sun Aug 05, 2007 12:15 am |
I'm a little confused with the filtering, I have played with CAN based on the examples but I made my own filtering system that only listens to messages with the devices ID on it (and a broadcast ID). It was a system thrown together for the company I work for.
How exactly would I gain the same effect using the can_set_id commands?
I used extended ID's btw.
It is set up like so:
#define my_id 0x11 // my ID
int1 tx_rtr=0; // was 1
int1 tx_ext=1; // was 0
int tx_len=8;
int tx_pri=3;
byte outdata[8];
int rx_len;
int i; |
I also have can_init() in the main function before I go into the main loop.
then when in the main() loop I poll the can_kbhit() check the ID attached to it and only accept if it matches my_id or broadcast (0xFF)
Say, one unit is id 0x11 and broadcast is 0xFF, I want unit 0x12 to send a message with the ID of 0x13. how would I counfigure the code below to ignore any message that is not addressed to ID 0x11 or 0xFF?
can_set_id(RX0MASK, 0x07FFFFFFF, CAN_USE_EXTENDED_ID); //set mask 0
can_set_id(RX0FILTER0, 0x0074, 1); //set filter 0 of mask 0
can_set_id(RX0FILTER1, 0x0074, 1); //set filter 1 of mask 0
can_set_id(RX1MASK, 0x07FFFFFFF, CAN_USE_EXTENDED_ID); //set mask 1
can_set_id(RX1FILTER2, 0x0074, 1); //set filter 0 of mask 1
can_set_id(RX1FILTER3, 0x0074, 1); //set filter 1 of mask 1
can_set_id(RX1FILTER4, 0x0074, 1); //set filter 2 of mask 1
can_set_id(RX1FILTER5, 0x0074, 1); //set filter 3 of mask 1 |
note: this code was taken from the other page of this thread.
also, would can_kbhit() and the can interupts ignore the non-addressed packets?
many thanks |
ferrumvir
Posted: Sun Aug 05, 2007 2:04 pm |
can_set_id(RX0FILTER0, 0x0011, 1); //set filter 0 of mask 0
can_set_id(RX0FILTER1, 0x00FF, 1); //set filter 1 of mask 0
can_set_id(RX1FILTER2, 0x00FF, 1); //set filter 0 of mask 1
can_set_id(RX1FILTER3, 0x00FF, 1); //set filter 1 of mask 1
can_set_id(RX1FILTER4, 0x00FF, 1); //set filter 2 of mask 1
can_set_id(RX1FILTER5, 0x00FF, 1); //set filter 3 of mask 1
The above code should set the chip up to recieve only the two IDs of interest. Have a look at a mistake I was making in this http://www.ccsinfo.com/forum/viewtopic.php?t=30984 thread if you want a little more insight. |
ratgod
Posted: Sun Aug 05, 2007 6:42 pm |
many thanks, I will try this tommorow when I get a chance. |
Posted: Sat Dec 08, 2007 4:17 pm |
ferrumvir: you mentioned you made a mistake, and it was the parameters list thing, did this allow you to filter different rxID's when you fixed it?
Code: | void can_filt( int16 rxid1,rxid2,rxid3,rxid4,rxid5,rxid6 )
can_set_mode(CAN_OP_CONFIG);
can_set_id(RX0MASK, 0x07FF, 0); //set mask 0 // MATCH MASK 100%
can_set_id(RX0FILTER0, rxid1, 0); //set filter 0 of mask 0
can_set_id(RX0FILTER1, rxid2, 0); //set filter 1 of mask 0
can_set_id(RX1MASK, 0x07FF, 0); //set mask 1 // MATCH MASK 100%
can_set_id(RX1FILTER2, rxid3, 0); //set filter 0 of mask 1
can_set_id(RX1FILTER3, rxid4, 0); //set filter 1 of mask 1
can_set_id(RX1FILTER4, rxid5, 0); //set filter 2 of mask 1
can_set_id(RX1FILTER5, rxid6, 0); //set filter 3 of mask 1
can_set_mode(CAN_OP_NORMAL);
this is your code from the linked thread, did it work when you changed the parameter list? also, does this allow you to select which rxID's to listen to?
thanks |
ferrumvir
Posted: Sun Dec 09, 2007 1:36 pm |
Once the parameter list for the function call was fixed, i.e. declaring each int16 the routine worked fine.
All the rxids come in to the can_kbhit or the interupts, you need to parse out which ID is being handled and handle it accordingly.
Hope that helps.
Cheers Scott |
ratgod
Posted: Tue Jan 29, 2008 9:09 pm |
I got my code working in the end,
I set the RX0 filters to 0x0011 (which is the boards ID) and the RX1 filters to 0x00FF (which is the broadcast ID) and using the separate RX0 and RX1 interrupts I have a separate interrupt for a direct addressed packet and broadcast packet.
on a side note, do you know if I can change the filters or even the speed of the CAN at run-time? I am designing a new system with a faster rate CAN and I want to be able to be able to use my CAN-RS232 module with both systems and select the speed via my PC software?
many thanks
Peter |
ferrumvir
Posted: Tue Feb 05, 2008 10:29 am |
Hi RatGod,
Yes you can reconfigure the speed at run time though you have to take the bus off line, use the can_set_mode function to take the bus off and on line and set the speed inbetween. Sorry I've not got access to my code so I can't tell you what the speed related registry settings are. Have a look in the example can_init() function.
// SET SPEED HERE
Cheers Scott |
