bschriek
Posted: Mon Nov 21, 2011 8:41 am |
I know, to reset the isr I must read the port but the reset of the interrupt is not the problem.
The real problem is the IOCAF register is always zero, so the program does NEVER reach the interrupt. So again the problem is not to leave the interrupt but to GO TO the interrupt.
I only simulated this program with MPlab and the Asynchronous PIN simulus but for hours. |
Posted: Mon Nov 21, 2011 5:35 pm |
I was able to make it work in hardware. I used compiler vs. 4.127 with a
Microchip "low pin count" board. I have Pin A1 jumpered over to one of
the LEDs on the board. When I press the push-button switch, the LED
toggles. I supply +5v power to the board from a bench power supply.
The ICD3 doesn't power the board.
#include <12F1822.H>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOMCLR
#use delay(clock=4M)
#define LED_PIN PIN_A1
#byte IOCAF = getenv("SFR:IOCAF")
#define clear_IOCA_flags() IOCAF = 0
#int_ra
void ra_isr(void)
output_toggle(LED_PIN);
delay_ms(10); // Debounce delay for testing purposes
clear_IOCA_flags(); // Clear flags after the debounce delay
output_low(LED_PIN); // Initialize LED to "Off".
port_a_pullups(0x08); // Enable pull-up on pin A3
clear_interrupt(INT_RA); // Clear any existing interrupt condition
clear_IOCA_flags(); // Clear any existing "change" condition
enable_interrupts(INT_RA3_L2H); // Interrupt when button is released
bschriek
Hardware OK, simulation fails |
Posted: Tue Nov 22, 2011 3:46 am |
Thank you pcm programmer.
The hardware works but the simulation with MPlab does NOT work.
We learned from the past to simulate first with MPlab because the registers of the WATCH window will inform you in an early stage about possible bugs of the CCS compiler. Due to manual bit settings most of the time we were able to make the program working until now.
I only got 1 warning left nr: 225 and it informs about a Duplicate define.
Best regards,
Bas |
norman_tan
INT_TIMER1 will disable INT_RA function in PIC12F1822? |
Posted: Sat Oct 19, 2019 1:47 am |
Dear PCM programmer,
I read your codes here and change pin_RA3 to pin_RA2, it also works well, very good.
And I add codes of INT_TIMER1(it also works well without enable INT_RA), then I find INT_RA does not work at all now!
Codes as below:
#use delay(clock=8M)
#define Launch_ON output_high(PIN_A5) // For Laser tube control
#define Launch_OFF output_low(PIN_A5) // For Laser tube control
unsigned char pulse_counter = 0; // record counting for LS led control in Timer1 interrupt
#int_ra
void ra_isr(void)
output_high(LED_PIN);
[color=red]
#INT_TIMER1
void clock1_isr()
pulse_counter++;
// codes below will generate pulse with period 115uS(_||______) as:
// 31us high and 84us low with setup_oscillator(OSC_8MHZ);
if(pulse_counter == 1) Launch_ON;
else if(pulse_counter == 2) Launch_OFF;
else if(pulse_counter >= 4) pulse_counter = 0;
set_timer1(0xFFFE); // 31uS/115uS
}[/color]
port_a_pullups(0x04); // Enable pull-up on pin A2
enable_interrupts(INT_RA2_L2H); // Interrupt when button is released
[color=red]set_timer1(0xFFFE); //
setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
enable_interrupts(INT_TIMER1); // used for pulse generation[/color]
And I also found I/O function input(PIN_A2) fails too if INT_TIMER1 used.
Would you please teach me how to solve this problem? |
Re: INT_TIMER1 will disable INT_RA function in PIC12F1822? |
Posted: Sat Oct 19, 2019 2:48 am |
norman_tan wrote: |
And I add codes of INT_TIMER1 (it also works well without enable
#INT_TIMER1
void clock1_isr()
pulse_counter++;
set_timer1(0xFFFE);
Your Timer1 reload value of 0xFFFE is way too small, in terms of time.
It's only two instruction cycles before it rolls over to 0x0000 and causes
an interrupt. With Fosc = 8 MHz, the instruction clock is 2 MHz. Each
instruction clock is 1/2 usec. So two clocks is 1 usec. That's your
interrupt rate.
By counting instructions in the .LST file, I calculate that the shortest
path through your Timer1 isr and through the compiler's interrupt handler
code will take about 27 usec. You can't interrupt every 1 usec, and then
take 27 usec (minimum) to process it. Your program will continuously
process the interrupt and them immediately jump right back into it.
There will be no processor time left to run the main program or anything
else. The net effect is that your program will appear to be locked up.
You need to substantially increase the time between Timer1 interrupts. |
Posted: Sat Oct 19, 2019 4:41 am |
As a comment, if you want to toggle a pin at that sort of speed, this can be
done using the PWM on pin A2 or A5. |
norman_tan
Posted: Sat Oct 19, 2019 8:11 pm |
Dear PCM Programmer and Ttelmah,
Thanks for your kindly reply!
According to advice from email of CCS support, I added command line "if(bit_test(input_a(),2))" in codes, it works well now.
but I will try to change the value in set_timer1(0xFFFE) to get a better pulse too. As said by PCM Programmer, "0xFFFE" will cause interrupt too frequently, hehe.
I also want to try the PWM from RA5, it is the first time I use this small chip, I am not familiar to some functions of it , I will try them.
Thanks again! |
norman_tan
norman_tan
Posted: Sat Oct 19, 2019 9:09 pm |
Additional remarks as below:
When I changed "setup_ccp1(CCP_PWM); " to "setup_ccp1(CCP_PWM|CCP1_A5); ", PWM generated on RA5 now, it works!
Thanks! |
Posted: Sat Oct 19, 2019 10:52 pm |
Well done. This is where reading what the .h file actually says helps.
Some things are 'single' values, while others need to be ored together
like this. |
norman_tan
Posted: Sun Dec 01, 2019 7:34 pm |
I am very regret that I met an issue as below,
pulse width on PA5 changed to unnormal 19us(interrupt happens on PA2) form normal 9us(no interrupt on PA2)!!!!
and I don't know how to solve it
All codes I attach here:
Code: | #define Launch_ON output_high(PIN_A5) // For Laser tube control
#bit IOCAF_2 = getenv("SFR:IOCAF").2
#define clear_IOCA_2_flags() IOCAF_2 = 0
#int_ra
void ra_isr(void)
clear_IOCA_2_flags(); // Clear flag of PA2
Initialization();
// pulse width on PA5 is 9.2us
Launch_ON;
delay_us(8);
Launch_OFF;
delay_us(450);
void Initialization(void)
setup_oscillator(OSC_16MHZ); // Set the internal oscillator to 16MHz
SET_TRIS_A(0x0C); // 00 1100: Set A5, A4, A1, A0 as output, A3, A2 as input
port_a_pullups(0x0C); // Enable pull-up on pin A2
SETUP_ADC_PORTS(NO_ANALOGS);
// set INT-RA interrupt
clear_interrupt(INT_RA2); // Clear any existing interrupt condition
clear_IOCA_2_flags(); // Clear any existing "change" condition
enable_interrupts(global); // Enabled all interruptions.
Posted: Sun Dec 01, 2019 8:41 pm |
If you don't want the 9us pulse to be lengthened by an interrupt occurring
during the pulse, then disable interrupts during the pulse. Example:
Quote: | while(TRUE)
disable_interrupts(GLOBAL);
Launch_ON;
delay_us(8);
Launch_OFF;
delay_us(450);
If you do it as shown above, then the 450us pulse low time could become 459us
if the interrupt occurs. |
norman_tan
Posted: Sun Dec 01, 2019 9:05 pm |
but, I shoud give a fixed period pulse with on PA5, and interrput happens only in the period of PA5 is high
Launch_ON;
delay_us(8);
Launch_OFF; |
