about kbd
PostPosted: Wed Oct 08, 2008 5:40 pm     Reply with quote
1. Put the incoming characters from the keypad into an array.
Make sure you don't write beyond the end of the array.
2. When the user presses the '#' key, this marks the end of the data.
Write a 0x00 to the end of the data in the array, when you get this key.
This will make the ASCII numbers into a string.
3. Now use the atoi() or atol() function to convert the numeric string
in the array into an integer. Those functions are in this file. You need
to #include it in your program:
c:\program files\picc\drivers\stdlib.h
