Get_String of Hex...
PostPosted: Fri Jun 20, 2008 9:24 pm     Reply with quote
I would like to capture a string of hex then store it into the EEPROM...
I assume you mean ASCII hex characters. The following routine
converts up to 2 digits of ASCII hex chars to an 8-bit unsigned int.
You can use strlen() to get the length of the string in your buffer.
Then use a for() loop to convert two digits per pass.
// Convert a string of 1 or 2 ascii hex characters to a binary value.
int8 axtoi(char *ptr)
int8 i, temp, value;
value = 0;
for(i = 0; i < 2; i++)       // Convert a maximum of 2 digits
    temp = toupper(*ptr++); // Get the char. Convert to upper case
    if(isxdigit(temp) == FALSE)  // Is ascii char a hex digit ?
       break;          // Break if not
    temp -= 0x30;      // Convert the char to binary
    if(temp > 9)
       temp -= 7;
    value <<= 4;       // shift existing value left 1 nybble
    value |= temp;     // Then combine it with new nybble
return(value);
Example:
char array[20] = {"0123456789ABCDEF"};
int8 len;
char *ptr;
int8 i;
len = strlen(array);
ptr = array;
for(i = 0; i < (len + 1)/2; i++)
    printf("%x \n\r", axtoi(ptr));
    ptr += 2;
