USB Example Code Compile Error
mbro131
interrupt warnings
PostPosted: Mon May 22, 2006 8:45 pm     Reply with quote
Ahh thats better. Should I be concerned about the 'Interrupts disabled during call to prevent re-entrancy' warnings?
Does this basically mean that the compiler disables interupts until these routines are finished? and if so should I be doing this explicitly?
Matt
PostPosted: Mon May 22, 2006 10:05 pm     Reply with quote
The usb_token_reset() function is called by:
usb_isr_rst()
usb_detach()
usb_attach()
The usb_task() function calls usb_attach(). This call is made outside
of an interrupt service routine.
The usb_isr() function calls usb_isr_rst(). This call is made from
within the #int_usb interrupt service routine.
There is only one instance of the usb_token_reset() function and it
is not re-entrant. Therefore, the compiler automatically inserts code
at compile-time to disable interrupts while usb_token_reset() is
executing.
mbro131
PostPosted: Mon May 22, 2006 10:08 pm     Reply with quote
Thankyou for clearing that up for me, much appreciated
Matt
