Posted: Fri Mar 17, 2006 1:49 pm |
Use printf to convert to ASCII. Use the re-direction feature of the CCS
printf() function to send the output to your lcd driver. Example:
#include <16F877.H>
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#include <lcd.c>
float value;
value = 1.243;
printf(lcd_putc, "%7.3f", value);
croc4
| Thank you!!! |
Posted: Fri Mar 17, 2006 2:11 pm |
Thanks, the printf, did the trick. I didn't know you could do that, I have a lot to learn.
Thanks again,
Croc4 |
gs
Joined: 22 Aug 2005 Posts: 30 Location: Ioannina - Greece
Posted: Sat Mar 18, 2006 7:52 pm |
You could also multiply with 1000 and print the result as 1000's,".",100's,10's,1's
If you want to avoid use of floats you could modify the calculations this way. _________________ www.hlektronika.gr |
