Deep Sleep wake up on INT0 !
Goto page Previous  1, 2
PostPosted: Tue Jun 07, 2011 6:14 pm     Reply with quote
This code appears to do what you want. Here is the output on TeraTerm:
DSWAKEL: 01 // DSPOR bit = 1. This is the initial power-up of the board.
DSWAKEH: 00
// Next, I pressed the pushbutton on Pin B0.
DSWAKEL: 00
DSWAKEH: 01 // DSINT0 = 1. The board woke-up on the falling edge.
// Then I released the pushbutton on pin B0.
DSWAKEL: 00
DSWAKEH: 01 // DSINT0 = 1. The board did a wake-up on the rising edge.
// Then I press and release the button again. It works here too.
DSWAKEL: 00
DSWAKEH: 01
DSWAKEL: 00
DSWAKEH: 01
And again, and it still works.
DSWAKEL: 00
DSWAKEH: 01
DSWAKEL: 00
DSWAKEH: 01
The pushbutton circuit looks like this:
           +3.3v
            > 10K
            <         ___ Push button switch
To          |        _|_|_
pin -----------------o   o------
B0                             |
                              --- GND
Here is the test program. I don't know if all the 10ms delays in here are
necessary. Some of them are. This program was tested with compiler
versions 4.095 and 4.121.
#include <18F24J11.h>
#fuses HS, NOWDT
#use delay(crystal=20M)
#byte WDTCON = 0xFC0
#byte DSCONH = 0xF4D
#byte DSCONL = 0xF4C
#byte RTCCFG = 0xF3F
#byte DSWAKEH= 0xF4b
#byte DSWAKEL= 0xF4a
#byte OSCCON = 0xFD3
#bit IDLEN =OSCCON.7      // Used to set IDLE low-power mode
#bit DSEN = DSCONH.7      // Used to set deep sleep
#bit REGSLP =WDTCON.7
#bit RELEASE = DSCONL.0
#bit RTCSYNC = RTCCFG.4
#bit DS_WAKEUP_BIT = WDTCON.3   // Bit that detects wake up from DS
#bit DSRTC = DSWAKEL.3
// Release the PIC's i/o pins for normal operation
// after waking up from Deep Sleep.  Important !
RELEASE = 0;
delay_ms(10);
printf("\n\r");
printf("DSWAKEL: %x \n\r", DSWAKEL);
printf("DSWAKEH: %x \n\r", DSWAKEH);
delay_ms(10);
// Clear the wake-up source registers, regardless
// of what the PIC data sheet says.
DSWAKEL = 0;
DSWAKEH = 0;
// Look at the current state of the push-button switch.
// Based on that, set the edge that we expect to see next.
if(input(PIN_B0) == 1)   // If switch is high
   ext_int_edge(H_TO_L); // Then expect a falling edge next
else                     // If switch is low
   ext_int_edge(L_TO_H); // Then expect a rising edge next
clear_interrupt(INT_EXT);
enable_interrupts(INT_EXT);
delay_ms(10);
// Enable Deep Sleep mode.
REGSLP = 1;    // enable low-power operation in sleep mode
IDLEN = 0;
#asm         // Time-critical section must be in ASM
BSF DSEN
SLEEP
NOP
#endasm
printf("Should never get here\n\r");
heUAcyp
PostPosted: Wed Jun 08, 2011 6:12 am     Reply with quote
Sir thank you very very much for your help.
Interrupt is working with a small problem. I have tested the suggested code and get the expected results on the HyperTerminal:
DS_WAKEUP_BIT: 00
DS_WAKEUP_BIT: 00
DSWAKEH: 00
DSWAKEL: 00
DS_WAKEUP_BIT: 01
DS_WAKEUP_BIT: 01
DSWAKEH: 01
DSWAKEL: 00
DS_WAKEUP_BIT: 01
DS_WAKEUP_BIT: 01
DSWAKEH: 01
DSWAKEL: 00
The code I am using is:
#include <18F25J11.h>
#device ADC=10
#include <STDIO.H>
#include <stdlib.h>
#include <math.h>
#include <STRING.H>
#include <2408.c>
#fuses HS,NOWDT,NOPROTECT
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
#byte INTCON = 0xFF2
#byte INTCON2 = 0xFF1
#bit IDLEN=OSCCON.7      // used to set IDLE low-power mode ( will be set to zero for both deep-sleep and sleep modes)
#bit DSEN = DSCONH.7     // used to set deep sleep (1 for deep-sleep)
#bit DSINT0 = DSWAKEH.0 // bit for INT0 interrupt - change detection
#bit DS_WAKEUP_BIT = WDTCON.3     // bit that detects wake up from deep sleep
#bit INT0IE = INTCON.4
#bit INT0IF = INTCON.1
#bit INTEDG0 = INTCON2.6
void EnterDeepSleep()
IDLEN = 0;
BSF DSEN
SLEEP
NOP
#endasm
void PerformingTaskON()
output_high(PIN_A1) ;
//disable_interrupts(GLOBAL);
RELEASE = 0;   // Activate i/o pins
delay_ms(10);
printf("\n\r\n\r");
printf("DS_WAKEUP_BIT:  %x \n\r", DS_WAKEUP_BIT);
delay_ms(10);
printf("DS_WAKEUP_BIT:  %x \n\r", DSINT0);
delay_ms(10);
delay_ms(10);
delay_ms(10);
if((DS_WAKEUP_BIT == 1) && (DSWAKEH == 1)&&(DSINT0==1))
PerformingTaskON() ;
delay_ms(200);
DSWAKEL = 0;
DSWAKEH = 0;
DSWAKEL = 0;
DSWAKEH = 0;
delay_ms(10);
EnterDeepSleep() ;
while(true)
However, PIC does not go back to sleep when I try to perform a task.
With a simple test task (if function commented in above code), when interrupt fires, I am turning a LED on. The problem is , LED does not turn back to off afterwards, meaning that PIC is not getting back to deep sleep mode.
in my complete design I will keep real time while in deep sleep , than wake up only to save the date and time to an external EEPROM when interrupt fires and go back to sleep. I have written and tested the other parts of the code and they are working. But I want PIC to be awake only while performing a task and than go back to sleep again.
Something is still wrong, I tried to add the if function to various places in the code flow and it still not working.
PostPosted: Wed Jun 08, 2011 12:25 pm     Reply with quote
I assume that setting pin A1 to high level turns the LED on. I don't see
any place in your code where you turn the LED off. You never set pin A1
to a low level.
Going into Deep Sleep mode doesn't turn it off. Read the data sheet:
4.6.2 I/O PINS DURING DEEP SLEEP
During Deep Sleep, the general purpose I/O pins will retain their previous states.
Download the PIC data sheet and read the whole section on Deep Sleep.
heUAcyp
PostPosted: Wed Jun 08, 2011 2:55 pm     Reply with quote
Thank you boss
Page 2 of 2
