Problems with DS1307
Goto page Previous  1, 2
PostPosted: Tue Feb 24, 2009 12:25 pm     Reply with quote
Do you have pull-up resistors or do you have series resistors ?
This is a series resistor. Don't do this:
PIC pin ------/\/\/\/-------- DS1307 pin
This is a pull-up resistor. You need 2 resistors. One on SCL and one
on SDA. Use a value from 2.2K to 4.7K:
    +5v ---/\/\/\/---
PIC pin ------------o---------- DS1307 pin
simons
PostPosted: Tue Feb 24, 2009 12:29 pm     Reply with quote
yes 4K7 pullups on both lines...
PostPosted: Tue Feb 24, 2009 12:42 pm     Reply with quote
If possible, post a schematic and a photo of the board which shows the
connections.
simons
PostPosted: Tue Feb 24, 2009 12:45 pm     Reply with quote
I'm using a test board which I bought some years ago.. i think i might don't have the schematic...
I'll try another method.. I'll build a brand new board without all the test equipment...
stay tuned.. this might work..
Page 2 of 2
