nuwanw
Posted: Thu Feb 05, 2015 1:50 am |
Yes, but here in Australia. It's nearly 3 degrees behind, can I put -3 for declination value ?
Thank you in advance |
nuwanw
Posted: Thu Feb 05, 2015 6:12 pm |
Hi sshahryiar,
Could you please let me know how to convert that 3 degrees to that value , here my issue is when I rotate the compass chip in a small amount , it displays huge angle, for an example, for 20 degree it indicates 60-80 degrees , however it gives the full scale from 0 to 360, I'm stucked and could you please give me a direction?
Thank you |
nuwanw
Hi sshahryiar,
Could you please let me know how to convert that 3 degrees to that value. Here my issue is when I rotate the compass chip in a small amount, it displays huge angle, for an example, for 20 degree it indicates 60-80 degrees However it gives the full scale from 0 to 360. I'm stucked and could you please give me a direction?
Thank you |
sshahryiar
Joined: 05 May 2010 Posts: 94 Location: Dhaka, Bangladesh
nuwanw
Posted: Fri Feb 06, 2015 10:40 pm |
It's 3 degrees positive east, do I need to convert 3 degrees to radiant ?
Thanks |
sshahryiar
nuwanw
Posted: Fri Feb 06, 2015 11:00 pm |
then the radiand value is +0.052359878, but it did not make a considerable difference, what may be the issue? |
sshahryiar
Possible Issues |
Posted: Fri Feb 06, 2015 11:30 pm |
Possible Issues:
1. Disturbance due to nearby metallic or electronic object(s)....
2. Tilting.... This is not a tilt compensated compass module likeHMC6352....
3. Interference from electrical sources generating considerable amount of magnetic disturbance....
4. Poor PCB design layout.... _________________ https://www.facebook.com/MicroArena
SShahryiar |
nuwanw
Posted: Sat Feb 07, 2015 2:51 am |
Ok thanks |
