Gabriel
Posted: Tue Jul 10, 2012 2:33 pm |
Quote: | Must i only send 1 command at a time ?
!Led1 1 |
Exactly.
NO multiple commands.
... what is pin D1 doing? do you see activity? _________________ CCS PCM 5.078 & CCS PCH 5.093 |
dasilvarsa
Posted: Tue Jul 10, 2012 2:43 pm |
OK It's working NOW
My module only outputs uppercase even if I send lower case SMS
Strange but true. I think it's a setting on the module.
I changed this line
const char CMD1[8][7]={"LED1 0","LED1 1","LED2 0","LED2 1","LED3 0","LED3 1","LED4 0","LED4 1"};
Thanks for the code,
If you have any other snippets please post. Lots of people working on GSM
nowdays.
Regards |
Gabriel
Posted: Tue Jul 10, 2012 3:23 pm |
Hey! Thats great news!
I'm really happy my code helped you!
nowdays. |
Right back at you!
should you modify or improve upon my code, please post it on this thread...
Gabriel _________________ CCS PCM 5.078 & CCS PCH 5.093 |
ArthurWong
Posted: Mon Jan 28, 2013 2:28 am |
Gabriel wrote: | Yeah... thats true... i dont know how i missed that...
WTF?
GET_CMD() should be int instead of void...
Thanks for picking that up...
G. |
Hi Gabriel
may i know what is the problem of it?
i also got the same problem
what i need to change for my coding? |
ArthurWong
Posted: Mon Jan 28, 2013 2:38 am |
ArthurWong wrote: | Gabriel wrote: | Yeah... thats true... i dont know how i missed that...
WTF?
G. |
Hi Gabriel
this problem solve but got another problem
Function used but not defined....DO_CMD SCR=871
Code: | if (GET_CMD())
if(DEL_SMS())
DO_CMD() ;
Gabriel
Posted: Mon Jan 28, 2013 7:19 am |
Hi Arthur,
EDIT: l just checked the code again... DO CMD was declared as a INT and definde as VOID... ive Changed the define to VOID now..
that should solve your problem.... sorry.
Nevermind:
Code: | */
The posted code should compile without any problems.
have you done any modifications to the code?
i assume you are trying to build on this code to control somthing other than LEDs...
DO_CMD() is defined (at least on the posted code) so your error must be something else....
In a few weeks im going to be posting an updated GSM/SMS code... A Generic GSM/SMS "Driver" if you will...you could wait for that if this is not urgent..
I'd recommend you only use the code posted on this thread as a learning exercise to get a general idea on how to do this kind of thing...
Post your code so that i may help you better..
G _________________ CCS PCM 5.078 & CCS PCH 5.093 |
ArthurWong
Posted: Mon Jan 28, 2013 8:38 am |
Gabriel wrote: | Hi Arthur,
Nevermind:
Code: | */
G |
actually i just want to try to on my C4 pin when receive message, but even i change your code and try to send the message, nothing change...i change all D1 into C4 for my LED output...i am using PIC16F876A with wavecom fastrack(M1206B)...software PIC C compiler...i dont have problem with sending sms, but got problem with receive sms..for storage i want to use sim storage..hope can get some advice from you and others too
Code: | #include <16f876a.h>
#include <string.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT
#use delay(clock=20000000) //must be 20 MHz
#use rs232 (baud=9600, bits=8, xmit=pin_c6, rcv=pin_c7, parity=n, stream=GSM)
void SerialInt(); // USART INT handler
int TEST_AT(); // Test Modem
int SET_MEM(); // Set used memory
int SET_PDU(); // Set PDU mode
int SET_CNMI(); // basically, set to receive alerts of new sms
int SMSALERT(); // waits for the sms alert.
int READ_SMS(); // cleans text message
void DO_CMD(); // does commands
int DEL_SMS(); // deletes SMS
int GET_CMD(); // gets command
int GET_OK(int Stop_Search); // Just searches for an OK.
volatile int counter_search=0; //counter to traverse the array
volatile int counter_read=0; //counter to fill the array
Volatile int HitCounter=0; // for string comparison
Volatile int Next_CMD=0;
volatile Char Recieve_String[70]; //buffer for incoming data
SET_TRIS_A( 0x00 ); // to avoid floating pins
SET_TRIS_B( 0x00 );
OUTPUT_B(0X00);
SET_TRIS_C( 0x80 );
enable_interrupts(INT_RDA); // enable RDA interrupts
enable_interrupts(GLOBAL); // enable global ints
output_high(PIN_C4); // blink for circuit 'ON' confirmation
output_low(PIN_C4);
output_low(PIN_C4);
Delay_ms(1000);
if(TEST_AT())
if(SET_MEM())
if(SET_PDU())
if(SET_CNMI())
if(SMSALERT())
if(READ_SMS())
if(GET_CMD())
if(DEL_SMS())
DO_CMD();
DEL_SMS();
int TEST_AT()
counter_read=0;
printf("AT"); //send command
putchar(0x0D); //send return ('enter' in hyperterminal)
While(counter_read<=8) //"A T \R \R \N O K \R \N" characters returned by modem
output_low(PIN_C4);
counter_read=0;
Delay_ms(500); // ignore all remaining characters received
if(GET_OK(0X0A))
Return(1);
else return(0);
int SET_MEM()
counter_read=0; //reset all counters.
printf("AT+CPMS=\"ME\",\"ME\",\"ME\""); //text part of the command.
putchar(0x0D); // enter
While(counter_read<25) // stay here, ignore first 25 chars
counter_read=0; // start filling up the array from cero...from here on, keep the incoming text for parsing
while(counter_read<=28) // acquire all pertinent text, I'm only looking for an "OK" but for now I'm keeping all incoming txt.
{ // maybe for future use...
counter_read=0;
Delay_ms(500); // ignore all remaining characters received..if any.
if(GET_OK(0X1C))
Return(1);
else return(0);
int SET_PDU()
counter_read=0;
printf("AT+CMGF=1"); //send command
While(counter_read<=15) // get all returned text
counter_read=0;
Delay_ms(500); // ignore all remaining characters recieved
if(GET_OK(0X0E))
Return(1);
else return(0);
int SET_CNMI()
printf("AT+CNMI=2,1,2,0,0"); //text part of the command.
While(counter_read<24) // read all data
counter_read=0;
Delay_ms(500); // ignore all remaining characters recieved..if any.
if(GET_OK(0X17))
Return(1);
else return(0);
int SMSALERT()
const char StrCMTI[]={"+CMTI"};
counter_read=0;
While(counter_read<=16) // read all data
output_high(PIN_C4); // signal ready to receive sms
counter_read=0;
output_low(PIN_C4); // off receive ready light.
counter_search=2;
HitCounter=0;
while((HitCounter!=5)&&(counter_search<8))
if(Recieve_String[counter_search]==StrCMTI[counter_search-2])
HitCounter++;
counter_search++;
if(HitCounter==0x05)
Return(1);
else return(0);
int READ_SMS()
counter_read=0;
printf("AT+CMGR=1"); // send command, MEMORY LOCATION OF SMS IS ALWAYS ONE, SINCE I DELETE THEM AFTER PROSCESING
putchar(0x0D);
delay_ms(3000); // long [spam] message... so give time, buffer will loop back one time...
// text will be on second fill.
counter_read=0;
if(GET_OK(0X45))
Return(1);
else return(0);
int GET_CMD()
const char CMD1[8][7]={"Led1 0","Led1 1","Led2 0","Led2 1","Led3 0","Led3 1","Led4 0","Led4 1"};
int offset=0;
int store_counter=0;
counter_search=0;
while((Recieve_String[counter_search]!='!')&&(counter_search<69)) // wait till command indicator is found '!'
counter_search++;
counter_search=counter_search+1; // increment one to actual first letter of command
store_Counter=counter_search; // store current position for multiple searches
NEXT_CMD=0; // NEXT_CMD keeps track of the command being read, thus used
while((HitCounter!=6)&&(NEXT_CMD<8)) // compare to all commands in list.
counter_search=store_Counter; // initialize counter search with stored counter value.
offset=0; // since value of counter is unknown use a separate counter for the const array
HitCounter=0; // counts number of equal letters found.
while((HitCounter!=6)&&(offset<=6)) // keeps the counters in check...to not overshoot. and compares the strings
if(Recieve_String[counter_search]==CMD1[NEXT_CMD][offset]) // if letter is found
HitCounter++;
offset++;
counter_search++;
if(HitCounter==6) // if 6 chars found...exit..
Return(1);
NEXT_CMD++; // if increase to search next command.
Return(0);
Void DO_CMD()
if(NEXT_CMD==0)output_low(PIN_B1);
if(NEXT_CMD==1)output_high(PIN_B1);
if(NEXT_CMD==2)output_low(PIN_B2);
if(NEXT_CMD==3)output_high(PIN_B2);
if(NEXT_CMD==4)output_low(PIN_B3);
if(NEXT_CMD==5)output_high(PIN_B3);
if(NEXT_CMD==6)output_low(PIN_C4);
if(NEXT_CMD==7)output_high(PIN_C4);
int DEL_SMS()
counter_read=0;
printf("AT+CMGD=1"); //send command
counter_read=0;
if(GET_OK(0X0E))
Return(1);
else return(0);
int GET_OK(Stop_Search)
counter_search=0;
while((Recieve_String[counter_search]!='O')&&(counter_search<Stop_Search)) //check buffer until an 'O' is found or 10 chars have been checked.
counter_search++; //obvious
if((Recieve_String[counter_search]=='O')&&(Recieve_String[counter_search+1]=='K')) //check for a 'K' after the 'O'
counter_search=0;
Return(1); //function returns true
Return(0);
counter_search=0;
#INT_RDA
void SerialInt()
Recieve_String[counter_read]=getchar();
counter_read++;
if(counter_read==69)counter_read=0;
Gabriel
Posted: Mon Jan 28, 2013 9:13 am |
A couple of things...
I know i put it there... but remove the TRIS settings... let the compiler do that ...
you are using C4 as your "status" pin, as well as the pin you are actually trying to control...
C4 blinks at the begining of the code, when TEST_AT runs, When the SMSALERT runs... and then when you send the module the !Led4 command...
i suggest changing the status LED to a diferent LED... to avoid confusion..
also something VERY important:
this code only checks the SMS's located in adress ONE(1).... and deletes the SMS's on the same address...
before testing the code, DELETE ALL SMS's in the module... so when the code is runing and you send an SMS the module will place it on memory location one....
for memory locations:
Look at the function SET_MEM()...
Code: | printf("AT+CPMS=\"ME\",\"ME\",\"ME\""); |
read the specific options for your module... i believe for sim card memory you should use "SM" instead of "ME"..
ArthurWong
Posted: Mon Jan 28, 2013 9:39 am |
I already delete all my sim message and remove the trisc and also change ME to SM.....but it look like no response (See no light and only blinking starting), even my GSM also no response (slow blink) and i also cant receive any notification....is it problem with my GSM or i should change it to TC35 GSM ?
When i change my sim to phone, i receive a lot of previous message that i sent. Is that also mean the coding cant read the SMS by using this GSM wavecom fastrack? really headache now....i just want to test receive SMS to activate the LED.
When i test with the hyper terminal it just show ( AT ) only...as i know it is because it not yet receive message so it can't move further. |
Gabriel
Posted: Mon Jan 28, 2013 12:47 pm |
If you test the PIC code on HyperTerminal,
You should see AT only... if you type back to the PIC "OK" and 7 (any)more characters, it will reply with the next line...
Your modem should have "local echo on"... ATE1
You need to ensure your comms PIC>CELL are 100% good...
Disable flow control...
Also if your cell module has no connection to the network, that's a different story which no amount of pic code can fix.
ArthurWong
Posted: Mon Jan 28, 2013 9:45 pm |
Gabriel wrote: | if you test the PIC code on Hiperterminal,
you should see AT only... if you type back to the PIC "OK" and 7 (any)more characters, it will reply with the next line...
..your modem should have "local echo on"... ATE1
you need to ensure your coms PIC>CELL are 100% good...
disable flow control...
also if your cell module has no conection to the network, thats a diferent story which no amount of pic code han fix..
G. |
that mean i should put ATE1 in my program ? and i also need to disable the flow control (become none)(AT+IFC=0,0)? |
ArthurWong
Posted: Tue Jan 29, 2013 2:38 am |
ArthurWong wrote: | Gabriel wrote: | if you test the PIC code on Hiperterminal,
G. |
Hi Gabriel i put ATE1 command like code below and i get always low output or LCD display just show "return"...it is ok with hyper teminal (if i put >8 character i will go back "initialize") but when i plug into GSM and test it just show "return" and not looping back....can get some advice fron you ?
If using tc35 GSM it will loop between "intialize" then go to "Return" repeating no end even though i send the sms to GSM.
int TEST_AT()
counter_read=0;
printf("AT\r\n"); //send command
printf("ATE1\r\n");
lcd_gotoxy(1,1);
lcd_putc("Initialize....");
output_low(PIN_C4);
lcd_gotoxy(1,1);
lcd_putc("Return");
counter_read=0;
delay_ms(500); // ignore all remaining characters received
if(GET_OK(0X0A))
Return(1);
else return(0);
Gabriel
Posted: Tue Jan 29, 2013 7:43 am |
1) _without_connection to the PIC (in hyperterminal), enable local echo, and disable flow control... save settings.
2) Send AT\r to the module, it should reply (including local echo): //"A T \R \R \N O K \R \N"
got that working? good... now...
3) connect the pic to hypertermninal using _the original posted code_..
you should see the pic send "AT"... and wait for a reply..
4) the you (reply) type into hyperterminal: //"A T \R \R \N O K \R \N"
for testing you can just type: ATXXXOKXX.. (8+characters)
the pic should then reply with the next command SET_MEM()...
do not modify the original code until you get it working...
ArthurWong
Posted: Tue Jan 29, 2013 10:26 am |
Gabriel wrote: | 1) _without_connection to the PIC (in hyperterminal), enable local echo, and disable flow control... save settings.
G. |
yup, that is work Gabriel in the hyperteminal that show "AT" then if i type more than 8 char it show the next command..
what can i do in the next step? i am using 16f876A ...i got LCD and i am using it...and on the same time how can i test my GSM with hyperteminal that state it got receive sms? in my board i just have pin_C4 as my LED output that why i send "!LED4 1" to turn on LED...the others i try use LCD display....just hope can command using the sms |
ArthurWong
Work Half |
Posted: Wed Jan 30, 2013 12:54 am |
Hi Gabriel, finally i manage to work until code below only...
I just can work until output_low(PIN_D1)(int SMSALERT()), but the problem is when i send "!LED4 1", the command look like can't read it and the output part "output_high(PIN_B4)(Void DO_CMD())" can't trigger after receive my message...
Just "output_low(PIN_D1)" then go back to starting again(int TEST_AT() )...
Code: | int SMSALERT()
counter_read=0;
output_high(PIN_D1); // signal ready to receive sms
counter_read=0;
output_low(PIN_D1); // off receive ready light.
counter_search=2;
HitCounter=0;
HitCounter++;
counter_search++;
