dbotkin
Joined: 08 Sep 2003 Posts: 197 Location: Omaha NE USA
Posted: Thu Oct 23, 2008 6:02 pm |
In my case:
PCW 4.079.
I'm using the 8/13/04 version, short but without variable arguments. Here's the current version of my test program:
#include <16F887.h>
#device *=16
#device adc=8
#device PASS_STRINGS=IN_RAM
#zero_ram
#FUSES INTRC_IO //Internal RC Osc, no CLKOUT
#FUSES PUT //Power Up Timer
#FUSES NOPROTECT //Code protected from reads
#FUSES NOIESO //Internal External Switch Over mode disabled
#FUSES BORV21 //Brownout reset at 2.1V
#use delay(clock=8000000,RESTART_WDT)
#use rs232(baud=BAUDRATE,parity=N,xmit=TXD,rcv=RXD,bits=8,errors)
/*$F*************************************************************************
* Copyright (C)pa 2004 Mark Norton
* Permission is hereby granted, free of charge, to any person obtaining
* a copy of this software and associated documentation files (the
* "Software"), to deal in the Software without restriction, including
* without limitation the rights to use, copy, modify, merge, publish,
* distribute, sublicense, and/or sell copies of the Software, and to
* permit persons to whom the Software is furnished to do so, subject to
* the following conditions:
* The above copyright notice and this permission notice shall be included
* in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.
* IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY
* CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT,
* TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
* SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* Functional
* Description: Implementation of sscanf() function for the CCS compiler
#include <string.h>
#include <stdlib.h>
/* Uncomment any of these to reduce the code size
Note that the HEX is a big hog
#define NO_FLOAT
// #define NO_INT
// #define NO_SIGNED_INT
// #define NO_STRING
// #define NO_HEX
DESCRIPTION: Converts string pointed to by s to an unsigned long (16 bit)
RETURN: result of the conversion
ALGORITHM: none
NOTES: the next position in the string is returned in endptr
long my_atoul(char *s, char *endptr, int base)
signed long result;
int index;
char c;
index = 0;
result = 0;
*endptr = s;
if (( !s ) || ( !*s ))
return ( 0 );
c = *s;
// increase index if positive sign is detected
if (c == '+')
c = *(++s);
// The number is a decimal number
if (base == 10)
while (c >= '0' && c <= '9')
result = 10*result + (c - '0');
c = *(++s);
else if (base == 16) // The number is a hexa number
if (c == '0' && (*(s+1) == 'x' || *(s+1) == 'X'))
s += 2;
c = *s;
c = toupper(c);
while ( 1 )
if (c >= '0' && c <= '9')
result = (result << 4) + (c - '0');
else if (c >= 'A' && c <='F')
result = (result << 4) + (c - 'A' + 10);
c = toupper(*(++s));
*endptr = s;
return(result);
DESCRIPTION: Converts string pointed to by s to a float
ALGORITHM: none
float my_atof(char * s, char *endptr)
float pow10 = 1.0;
float result = 0.0;
int sign = 0;
char c;
c = *s;
if(c == '-')
sign = 1;
c = *(++s);
else if(c == '+')
c = *(++s);
while((c >= '0' && c <= '9'))
result = 10*result + c - '0';
c = *(++s);
if (c == '.')
c = *(++s);
pow10 = pow10*10;
result += (c - '0')/pow10;
c = *(++s);
if (sign == 1)
result = -1*result;
*endptr = s;
return(result);
DESCRIPTION: Implementation of scanf() using CCS C compiler
RETURN: total number of arguments read
ALGORITHM: none
NOTES: none
int8 sscanf(
char *buf, /* pointer to the buffer that we are scanning */
char *fmt, /* pointer to the format string */
char *pArgs) /* pointer to array of arguments */
int8 count = 0;
char *p;
int1 size_long;
int1 sign;
char *endptr;
while (1)
/* Look to see if we are out of arguments */
if ( !pArgs )
return( count );
/* Gobble up the fmt string */
while (*buf == *fmt)
if ((*buf == 0) || (*fmt == 0))
return (count);
buf++;
fmt++;
/* Check for the % */
if (*fmt != '%')
/* fmt should be '%' go to the next character */
fmt++;
/* get the size modifier */
switch (*fmt)
case 'l':
case 'L':
fmt++;
size_long = TRUE;
default:
size_long = FALSE;
/* fmt should point to our first conversion letter at this point */
switch (*fmt)
#ifndef NO_FLOAT
case 'f':
case 'F':
/* Get a pointer to this argument */
p = (float *)(*pArgs);
/* convert to a number */
*(float *)p = (float)my_atof(buf, &endptr);
/* Make sure that we succeeded */
if ( buf == endptr )
return ( count );
buf = endptr;
/* count this one */
count++;
#ifndef NO_SIGNED_INT
case 'd':
case 'D':
p = (signed int8 *)(*pArgs);
if (*buf == '-')
buf++;
sign = TRUE;
sign = FALSE;
if ( size_long )
*(signed int16 *)p = (signed int16)my_atoul(buf, &endptr, 10);
if (sign)
*(signed int16 *)p = -(*(signed int16 *)p);
*(signed int8 *)p = (signed int8)my_atoul(buf, &endptr, 10);
if (sign)
*(signed int8 *)p = -(*(signed int8 *)p);
return ( count );
buf = endptr;
count++;
#ifndef NO_INT
case 'u':
case 'U':
p = (int8 *)(*pArgs);
if ( size_long )
*(int16 *)p = (int16) my_atoul(buf, &endptr, 10);
*(int8 *)p = (int8) my_atoul(buf, &endptr, 10);
return ( count );
buf = endptr;
count++;
#ifndef NO_STRING
case 's':
p = (char *)(*pArgs);
/* copy the chars */
while (1)
if ((isspace(*buf)) || (!*buf))
*p = 0;
*p = *buf;
p++;
buf++;
count++;
#ifndef NO_HEX
case 'x':
case 'X':
if ( size_long )
*(int16 *)p = (int16) my_atoul(buf, &endptr, 16);
*(int8 *)p = (int8) my_atoul(buf, &endptr, 16);
return ( count );
buf = endptr;
count++;
/* unhandled format specifier */
default:
return (count);
/* Technically this is incorrect but since the size of all pointers
are the same, who cares ;)
point to the next argument
pArgs += sizeof(char *);
/* Move to the next format char */
fmt++;
return (count);
char x;
char sbuffer[64];
char cmd=0,param=0;
long l;
set_tris_a(0x80);
port_b_pullups(0xFF);
set_tris_b(0xFF);
set_tris_d(0);
set_tris_e(0x01);
setup_oscillator(OSC_8MHZ);
setup_adc_ports(sAN5|VSS_VDD);
set_adc_channel(5);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_2);
setup_timer_2(T2_DIV_BY_16, 155, 1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(75);
sprintf(sbuffer,"/S30\n\");
x = sscanf(sbuffer,"/%C%d", &cmd, ¶m);
printf("\n\rsscanf sez: %u found, cmd %X param %X\n\r",x,cmd,param);
Posted: Thu Oct 23, 2008 6:18 pm |
Quote: | sprintf(sbuffer,"/S30\n\"); |
The compiler doesn't like having the start of an escape sequence,
but without an identifier. i.e., you have a backslash at the end
without anything after it. (Probably it's supposed to be "\r").
Quote: | x = sscanf(sbuffer,"/%C%d", &cmd, ¶m); |
Mark's function takes 3 arguments, as shown below. You've got 4 of them
in the code above.
dbotkin
Posted: Thu Oct 23, 2008 10:52 pm |
PCM programmer wrote: |
in the code above.
OK... I did some more digging and I think I figured out how to do that. I now have:
char arglist[2];
arglist[0] = &cmd;
arglist[1] = ¶m;
strcpy(sbuffer,"/S30");
x = sscanf(sbuffer,"/%C%d",arglist);
Voila! It compiles. Thanks for the tip; I'd never done an array of args before, it took me a while to figure out how to do that. My apparent inability to grasp the finer points of indirection and such is no doubt the reason I'd never be able to make an honest living writing code.
And the output is... (drum roll)...
Code: | sscanf sez: 0 found, cmd 00 param 00 |
I've played around with it for a while now, always with the same result. |
robinaspey
Joined: 01 Oct 2008 Posts: 4 Location: England (for time being)
Posted: Fri Oct 24, 2008 2:40 am |
I got it to work in the end but there are probably some elements of ansi sscanf syntax that dont work correctly . Otherwise in the end it worked fine and I am very grateful for the code.
You just need to stick with it and test any code you write with an ANSI compatible compiler for windows such as DEV-C++ _________________ Thanks in advance ... |
RUFINOGG
scanf() |
Posted: Tue Dec 14, 2010 3:34 am |
PCM programmer wrote: | For everyone:
If you say it doesn't compile, you need to post your compiler version.
Also say if you're trying to compile the code in Mark's original post
or the shorter version that he posted later.
Tell if you're using Mark's test program or your own test program.
If it's your own, then post it. |
When compiling sscanf () gives me this error:
Attempt to create a pointer to a constant |
