baklou
Posted: Wed Feb 19, 2014 1:31 am |
Thank you for the over-writing issue, I totally missed it. I changed a lot of things in your "two boards" test program because the communication doesn't work even between board #1 and #2 in the first "way" to go. So I focused on a "simple" communication, so just board #1 to board #2.
About the CAN library, I just modified the can_init() function, and more particularly the "CAN_RX_MODE", and add the I/O settings in this function
set_tris_c((*0xF94 & 0xBF ) | 0x80);
So finally, here is my can_init() routine, which I didn't change a lot :
void can_init(void) {
can_set_mode(CAN_OP_CONFIG); //must be in config mode before params can be set
can_set_baud();
curfunmode=CAN_FUN_OP_LEGACY;
// RXB0CON
// filthit0=0
// jtoff=0
// rxb0dben=1 buffer zero will overflow into buffer one
// rxrtrro=0
// rxm1:0=0 will receive all valid IDs
RXB0CON=0;
RXB0CON.rxm=CAN_RX_ALL;
RXB0CON.rxb0dben=CAN_USE_RX_DOUBLE_BUFFER;
RXB1CON=RXB0CON;
CIOCON.endrhi=CAN_ENABLE_DRIVE_HIGH;
CIOCON.cancap=CAN_ENABLE_CAN_CAPTURE;
CIOCON.tx2src=CAN_CANTX2_SOURCE; //added for PIC18F6585/8585/6680/8680
CIOCON.tx2en=CAN_ENABLE_CANTX2; //added for PIC18F6585/8585/6680/8680
can_set_id(RX0MASK, CAN_MASK_ACCEPT_ALL, CAN_USE_EXTENDED_ID); //set mask 0
can_set_id(RXFILTER0, 0, CAN_USE_EXTENDED_ID); //set filter 0 of mask 0
can_set_id(RXFILTER1, 0, CAN_USE_EXTENDED_ID); //set filter 1 of mask 0
can_set_id(RX1MASK, CAN_MASK_ACCEPT_ALL, CAN_USE_EXTENDED_ID); //set mask 1
can_set_id(RXFILTER2, 0, CAN_USE_EXTENDED_ID); //set filter 0 of mask 1
can_set_id(RXFILTER3, 0, CAN_USE_EXTENDED_ID); //set filter 1 of mask 1
can_set_id(RXFILTER4, 0, CAN_USE_EXTENDED_ID); //set filter 2 of mask 1
can_set_id(RXFILTER5, 0, CAN_USE_EXTENDED_ID); //set filter 3 of mask 1
// set dynamic filters
can_set_id(RXFILTER6, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER7, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER8, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER9, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER10, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER11, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER12, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER13, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER14, 0, CAN_USE_EXTENDED_ID);
can_set_id(RXFILTER15, 0, CAN_USE_EXTENDED_ID);
set_tris_c((*0xF94 & 0xBF ) | 0x80); // C7 as input and C6 as output
can_set_mode(CAN_OP_NORMAL);
I know exchanging files here is not allowed, so don't ask to you to give me back the original file. But I never modify things I don't understand. Anyway, I don't really know if my problem is software or hardware. I even changed my two PICs, maybe a factory default...but nothing.
I really start to become crazy... |
Posted: Thu Feb 20, 2014 12:28 am |
I was able to make my two board CAN bus test program work. I only
have one 18F46K80, so I used that on Board #2. I used an 18F2580
on Board #1. I didn't have two 8 MHz crystals so I used two 20 MHz
crystals. I can type into TeraTerm and see the typing OK.
I have posted a link to a photo of my test setup at the bottom. I am using
jumper wires as the "can bus". But I have MCP2551's and 120 ohm
resistors at each end. Note that I have a black ground jumper between
the two boards. This article says the CAN Bus needs one:
http://www.edn.com/electronics-blogs/dev-monkey-blog/4408712/Does-The-CAN-Bus-Need-a-Common-Ground-
I edited the can_init() routine in can-18F4580.c to set the correct TRISC,
the same as you did. That's the only change I made to that file. I left
this line unchanged:
Code: | RXB0CON.rxm=CAN_RX_VALID;
One problem in your early code was that you didn't specify a fuse for
your 8 MHz crystal. So the compiler used the INTRC_HP fuse by default.
You were not running off the crystal but rather the internal oscillator.
Possibly this was the source of your problem (too many errors).
But you fixed that problem by using the HSM fuse in your later code.
Here is the program for Board #2 which has the 18F46K80:
#include <18F46K80.h>
#fuses HSH, NOPROTECT, PUT, BROWNOUT, NOWDT, NOPLLEN
#fuses CANC // *** Baklou is using CANC
#use delay(clock=20000000)
#include <can-18F4580.c> // Use correct driver
#define BOARD1_ID 24
#define BOARD2_ID 25
// Uncomment this line to compile code for Board #1.
// Comment it out to compile for Board #2.
//#define BOARD1 1
struct rx_stat rxstat;
int32 rx_id;
int32 tx_id;
int8 rx_len;
int8 buffer[8];
can_init();
#ifdef BOARD1 // For Board #1
buffer[0] = getc(); // Wait for a character
// Transmit it to board #2.
can_putd(BOARD2_ID, buffer, 1, 1, 1, 0);
buffer[0] = 0; // Clear the buffer byte
// Wait for the char to be echoed back.
while(!can_kbhit());
if(can_getd(rx_id, buffer, rx_len, rxstat))
if(rx_id == BOARD1_ID) // Is it for this board ?
putc(buffer[0]); // If so, display the char
#else // For Board #2
if(can_kbhit()) // Message available ?
// If so, get the message.
if(rx_id == BOARD2_ID) // Is it for this board ?
// If so, echo back the character.
can_putd(BOARD1_ID, buffer, 1, 1, 1, 0);
This is the Board #1 code:
#include <18F2580.h>
#fuses HS, NOPROTECT, PUT, BROWNOUT, NOWDT, NOLVP
#define BOARD1 1
int32 rx_id;
int32 tx_id;
int8 rx_len;
int8 buffer[8];
can_init();
The photo in the link below shows the test setup. The green and yellow
jumper wires are needed because my MCP2551 is hardwired to the CAN
bus pins on PortB. To test the PortC pins (which you are using), I
jumpered them over.
http://s27.postimg.org/itynzzckj/Two_CAN_bus_boards.jpg |
baklou
Posted: Thu Feb 20, 2014 9:31 am |
You really miss nothing ! lol effectively I made this mistake, and I saw it leaving the NOFCMEN fuse.
Anyway, after checking all of the stuffs, I think this only can be the oscillator frequency which is the problem...because it's the only thing which differs in my project than yours (and all the others) and as written on the can-18F4680 library, all the defaults settings are defined for this clock frequency...And I effectively still use this defaults settings...
I order a delivery for 20Mhz frequency oscillators, I will tell you this tomorrow.
Thank you a lot |
baklou
Posted: Mon Feb 24, 2014 4:00 am |
Hello everybody,
I come back again and for the last time. Instead of waiting for a new oscillator, I calculate again the good values to have a 125 Kbps CAN bus. And nothing has changed.
So I decided to change again my two transceivers, because of the previous issue I met, I was wondering...
And it is. It was my f***ing transceivers...from the beginning. Sorry to be so angry but on six transceivers ordered, I had at least two of them which was wrong....
Anyway, thanks to PCM Programmer to allow me his time and his advices.
Good news for a Monday morning
Thanks Greg |
gpsmikey
Posted: Mon Feb 24, 2014 10:56 am |
Well, that's a good start to the week !!
mikey _________________ mikey
