Posted: Sun Feb 13, 2011 3:07 pm |
This program should work with vs. 4.110:
#include <18F26K22.h>
#device adc=10
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#use delay(clock=4M)
int16 result;
setup_adc_ports(sAN0);
setup_adc(ADC_CLOCK_DIV_4);
set_adc_channel(0);
delay_us(10);
result = read_adc();
printf("%lx \n\r", result);
I tested it with an 18F45K22 in hardware, with vs. 4.110, and it worked.
It displayed these values in the terminal window as I turned a trimpot
from one end to the other:
Quote: |
0001
0001
0034
014a
01a7
023d
032d
03ae
03ff
03ff |
bdrmachine
Posted: Sun Feb 13, 2011 3:14 pm |
Thanks for the reply I'll test it out. In the mean time I have the program working using manual setting of registers and testing / toggling the GO/DONE bit.
#byte ANSELA = 0xf38
#byte ANSELB = 0xf39
#byte ANSELC = 0xf3a
#byte ANSELD = 0xf3b
#byte ANSELE = 0xf3c
#byte ADCON0 = 0xfc2
#byte ADCON1 = 0xfc1
#byte ADCON2 = 0xfc0
#byte CM1CON0 = 0xf78
#byte CM2CON0 = 0xf77
//setup_adc(ADC_CLOCK_INTERNAL);
//setup_adc_ports(sAN0|VSS_VDD);
ANSELA = 1;
ANSELB = 0;
ANSELC = 0;
ANSELD = 0;
ANSELE = 0;
ADCON0 = 1; //AN0 (only) selected and a/d enabled
ADCON1 = 0; //Vss & Vdd are reference
ADCON2 = 0x81; //Rigth justify,
CM1CON0 = 0;
CM2CON0 = 0;
Thanks Again
Brian |
bdrmachine
Posted: Sun Feb 13, 2011 7:47 pm |
I tested the code with my hardware and I get the same results as before (ANSELA remains at POR value).
The manual register select code work as expected.
Brian |
Posted: Sun Feb 13, 2011 8:53 pm |
The POR (power-on-reset) value of ANSEL is "all 1's" for the analog bits.
This means they are all configured as analog pins on power-up. I looked
at the .LST file for vs. 4.110 and it doesn't write to ANSELA (0xF38).
It leaves it in the power-on-reset state. |
bdrmachine
Posted: Mon Feb 14, 2011 8:01 am |
I thought [setup_adc_ports(sAN0|VSS_VDD);] would have set ANSEL to 0x01 but it doesn't. Armed with this knowledge all I should have to do is make sure I manually set ANSEL.
Brian |
gpsmikey
Posted: Mon Feb 14, 2011 10:01 am |
Glad you got it working. Some of those "features" can drive you nuts !
mikey _________________ mikey
bdrmachine
Posted: Mon Feb 14, 2011 10:31 am |
Only with all of your help!
Brian |
