Const struct
PostPosted: Fri Jun 17, 2016 10:54 am     Reply with quote
CCS quickly emailed me a new PCH.DLL file. I used it to replace the one
in the DLL\5.059\ subdirectory in the CCS folder. It fixed the problem.
When I ran the test program shown below in MPLAB vs. 8.92 simulator
it displayed the following results in the Output Window. This is the correct output:
> Menu1
> Menu2
> Menu2 sub1
> Menu2 sub2
Test program:
#include <18F46K20.h>
#fuses INTRC_IO, NOWDT, PUT, NOPROTECT, NOBROWNOUT
#use delay(clock=16M)
#define ALL_MENU  4
enum ids{   _BEGIN,
            _MAIN,
            _MAIN1,
            _MAIN11,
            _MAIN12
struct TypeMenu {
             int8 MenuID;
             int8 SubMenu;
             char MenuName[18];
const struct TypeMenu MenuTest[ALL_MENU]
        {_MAIN, _BEGIN,"Menu1"},
        {_MAIN1,_BEGIN,"Menu2"},
        {_MAIN11,_MAIN1,"Menu2 sub1"},
        {_MAIN12,_MAIN1,"Menu2 sub2"}
struct TypeMenu MenuPointer[2];
int8 i;
int8 k;
k = 0;
for(i = 0; i < ALL_MENU; i++)
    MenuPointer[k] =  MenuTest[i];
    printf("> %s \r", MenuPointer[0].MenuName);
while(TRUE);
After installing the new PCH.DLL file, the compiler reports its version as
5.060. If you need this DLL file, contact CCS (if you own the compiler)
or wait for vs. 5.060 to be released.
in_nursery
PostPosted: Mon Jun 20, 2016 5:45 am     Reply with quote
thanks PCM programmer for your time and support.
I will contact ccs.
younder
PostPosted: Sun Oct 09, 2016 8:56 pm     Reply with quote
Hi in_nursery
I'm still facing the same problem as yours. With latest CCS Compiler version this menu code doesn't work! Were you able to found a solution for this other than compile the code with 5.50?
Hugo
Hugo Silva
PostPosted: Mon Oct 10, 2016 3:22 am     Reply with quote
I don't think you have the same problem.
The fix, is there in 5.061, 5.062, and 5.064 (just tested all of them, and they run fine).
