Posted: Sat Feb 19, 2011 1:25 pm |
Run a simple test program. Then look at Pin C3 for the SPI clock.
Example:
#include <18F452.h>
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP
#use delay(clock = 20000000)
setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_64);
spi_write(0x55);
delay_us(100);
Don't run it in Debug mode. Don't attempt to step through the code.
Compile and run it in Release mode. You should see the SPI clock. |
Nora
Posted: Sat Feb 19, 2011 1:33 pm |
I DO see the clock.
Thanks! |
Posted: Sat Feb 19, 2011 4:17 pm |
And, on sending 16bits, just send two lots of 8bits. The _hardware_ only sends 8bits at a time, and if you load a new byte immediately, the transaction is effectively 'non stop' (which shouldn't matter anyway with SPI - this is why it sends a clock...).
