analog inputs sourcing too much current?
PostPosted: Mon Jun 07, 2010 4:50 pm     Reply with quote
setup_adc_ports(sAN0);
setup_adc_ports(sAN1);
setup_adc_ports(sAN2);
setup_adc_ports(sAN3);
setup_adc_ports(sAN4);
setup_adc_ports(sAN8);
This is not correct. The setup function is not cumulative. You need to
change it to use one call to the function, and Bitwise OR (with the |
operator) the sANx values together. Example:
setup_adc_ports(sAN0 | sAN1 | etc. );
The reason for the high current is explained in this section of the
16F886 data sheet:
9.1.1 PORT CONFIGURATION
Note: Analog voltages on any pin that is defined
as a digital input may cause the input
buffer to conduct excess current.
Your code was only making sAN8 (the last one) into an analog input.
The rest of them were digital.
picj1984
PostPosted: Mon Jun 07, 2010 5:20 pm     Reply with quote
Thanks so much!!!
bkamen
PostPosted: Mon Jun 07, 2010 5:37 pm     Reply with quote
And for correctness, analog (or any) inputs typically don't "source current".
-Ben
Dazed and confused? I don't think so. Just "plain lost" will do. :D
picj1984
PostPosted: Mon Jun 07, 2010 5:56 pm     Reply with quote
Hey guys,
They all work now except for sAN3. It's still doing the same thing. Is it possible I did some physical damage to the PIC? (although I do have a 50 mA resettable fuse protecting the circuit).
Here is the new code
void main ()
 in_c2 = input_state(PIN_C2);
 if(in_c2 == lo)
  setup_ccp1(CCP_CAPTURE_RE);
 else if(in_c2 == hi)
  setup_ccp1(CCP_CAPTURE_FE);
 setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
 setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
 setup_timer_2(T2_DIV_BY_1,90,1);
 setup_ccp2(CCP_PWM);
 setup_adc_ports(sAN0 | sAN1 | sAN2 | sAN3 | sAN4 | sAN8);
 setup_adc(ADC_CLOCK_DIV_32);
 set_adc_channel(0);
 delay_us(10);
 reload = read_adc();
 enable_interrupts(INT_CCP1);
PostPosted: Mon Jun 07, 2010 7:02 pm     Reply with quote
It's possible. Try a new PIC.
picj1984
PostPosted: Tue Jun 08, 2010 4:11 pm     Reply with quote
I had a solder bridge on a3. Everything works perfect now, thanks again.
