Posted: Mon Jun 07, 2010 11:21 am |
Try a more simple program that will display ADC values from 0 to 1023
based on the input voltage. Also, make sure you have a ground
connection between the device that supplies the ADC input voltage and
the PIC board's ground. You can't just have the input signal wire to
pin A0. There must also be a ground wire between the two devices,
connected to the ground on each device (or board).
#include <18F2525.h>
#device adc=10
#fuses INTRC_IO, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP
int16 adc_value;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_DIV_4);
set_adc_channel(0);
delay_us(20);
adc_value = read_adc();
printf("%lu", adc_value);
