Posted: Fri Mar 05, 2010 11:38 pm |
I've modified your program so it should work. If press the button on
pin B7 down, the LED will go on. When you release the button, the LED
will go off.
#include <16F886.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOLVP
#define SW_PIN PIN_B7
#define LED_PIN PIN_A1
#int_rb
void rb_isr(void)
int8 value;
output_toggle(LED_PIN);
delay_ms(10);
value = input(SW_PIN);
int8 temp;
output_low(LED_PIN);
temp = input(SW_PIN);
clear_interrupt(INT_RB);
enable_interrupts(INT_RB7);
