Posted: Wed Oct 14, 2009 4:41 pm |
This Microchip ASM code could be converted to CCS:
http://www.analog.com/static/imported-files/application_notes/317740795RMS_CODE.txt
Converting it to use CCS functions would greatly reduce the number of
lines of code. Here's an example:
I have converted the SPIRX and ENGREAD1 functions to CCS.
I didn't try to improve it very much. They use globals to transfer
data. For simplicity, I just kept it that way. That could be improved.
Compare this code to the ASM code in the link. But remember,
I don't want to do this project for you. This is just an example to
help you to see how to convert the code in a minimal way. You must
do the rest of it, if you want to.
#include <16F877.H>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS)
// SPI mode constants used in the setup_spi() function.
#define ADE7756_CS PIN_B4
#define RSTENERGY_CMD 0x03
int8 insd5;
int8 insd4;
int8 insd3;
int8 insd2;
int8 insd1;
void SPIRX(int8 spi_command, int8 wordlen)
output_low(ADE7756_CS);
spi_write(spi_command);
insd1 = 0;
insd2 = 0;
insd3 = 0;
insd4 = 0;
insd5 = 0;
// This switch-case code intentionally leaves out the break
// statements, because it is intended to "fall through" to
// get all the required bytes (from 1 to 5, depending on
// the parameter passed to the SPIRX() function).
switch(wordlen)
case 5:
insd5 = spi_read(0);
case 4:
insd4 = spi_read(0);
case 3:
insd3 = spi_read(0);
case 2:
insd2 = spi_read(0);
case 1:
insd1 = spi_read(0);
default:
printf("Error: Incorrect wordlen\n\r");
output_high(ADE7756_CS);
void ENGREAD1(void)
SPIRX(RSTENERGY_CMD, 5); // 40 bits = 5 bytes
// The ADE7756 will be connected to the 3 hardware SPI pins
// on the PIC. A spare i/o pin is used for the Chip Select.
// The max allowable SCLK is 3 MHz, so a divisor of 4 is used
// with our 4 MHz crystal, to give 1 MHz SCLK.
setup_spi(SPI_MASTER | SPI_MODE_1 | SPI_CLK_DIV_4);
delay_ms(10);
ENGREAD1();
// The result from the ENGREAD1() function is returned in
// 5 global variables. Display them.
printf("%x %x %x %x %x \n\r" insd5, insd4, insd3, insd2, insd1);
Edit: Fixed a problem where I left ADE7756_CS in a low state
at the end of SPIRX(). Also added code to initialize it to a high
level at the start of main() and do a short delay after that.
Last edited by PCM programmer on Thu Oct 15, 2009 5:30 pm; edited 1 time in total |
gomond
Posted: Thu Oct 15, 2009 3:13 am |
Thanks Heaps PCM Programmer
That is a ripper kick start. I would have never thought that it could be simpilfied like that.
Being a fitter and turner this stuff takes a while to convert to nuts and bolts but with help like this I can at least get my head arround it.
Thanks again.
Greg. |
