Here is demo program for the ADC on the 10F222. This was tested in
hardware with vs. 4.073.
A 10K trimpot was connected between +5v and ground. The wiper of
the trimpot was connected to the AN0 pin (GP0) on the 10F222. Pin GP2
was connected to the Rx pin (pin 2 on a DB9) on the COM1 port on the
PC. Pin 5 on the DB9 was connected to ground on the 10F222 board.
There is a 10K pull-up resistor on the MCLR pin.
While running the program, the trimpot was turned from one limit to
the other limit. The follow output was displayed in a terminal window
on the PC. This is correct output.
