Posted: Wed Mar 04, 2009 2:47 pm |
I suggest that you start with a simple program that doesn't use the RTOS.
Make that program work first. Here's an example:
Code: | #include <16F877A.h>
#use rs232(baud=2400,xmit=PIN_E0,rcv=PIN_E1)
if(input(PIN_C0)) // Read the switch pin.
putc('1'); // Display the state of the pin.
putc('0');
Make sure that pin C0 has a pull-up resistor on it. You can use 4.7K or
10K. |
