Posted: Tue Oct 07, 2008 11:00 am |
Quote: |
I can't seem to restart the wdt.
While running the ICD, I halt the program and find values less than 0xFF00.
I don't know about the CCS ICD, but the help file for the Microchip ICD2
says this:
Quote: | Debugger Limitations
The Watchdog Timer (WDT) cannot be used when debugging. |
The CCS ICD probably has the same limitation. |
tvlodek
Posted: Tue Oct 07, 2008 11:51 am |
I tried running the board stand alone and it still won't run right. I was able to set the wdt for sleep mode (divide by 1) then changed it to 2304MS and it was running right, I still wasn't able to set timer1 correctly but I only needed to get the timing right. Now I'm back to the drawing board.... As soon as I press the "run" button, it goes back to sleep, even though I attempt to clear the wdt numerous times in the ISR...... That, and MPLAB is just a pain in the neck, hanging up my computer, watching the hourglass for 5 minutes at a time, etc...... I don't know if this is a MPLAB thing or what..... Maybe I'll try running out of the CCS IDE..... |
Posted: Tue Oct 07, 2008 11:59 am |
Post a very short program that demonstrates the problem. Here's an
example of what I mean:
http://www.ccsinfo.com/forum/viewtopic.php?t=28158&start=8
It's super short, and it shows how to wake up from sleep with Timer1.
The program that you post must be compilable without errors. It must
have the #include, #fuses, #use delay(), main(), variable declarations,
etc. Don't put in any Wizard code that is unrelated to demonstrating
the problem. i.e., don't put in code to setup the A/D, when your
problem is about the WDT. Most importantly, the program must be short. |
