Function with pin in parameter
PostPosted: Wed Mar 05, 2008 12:16 pm     Reply with quote
Use the CCS pin numbers. These numbers encode the port address
and the bit position of the pin in one number. Use the constants that
are listed in the .H file for your PIC, such as PIN_B1, etc.
The pin numbers consists of the bit position in the lower 3 bits, and
the port address in the upper bits (shifted left by 3 bits).
Franck26
PostPosted: Wed Mar 05, 2008 2:32 pm     Reply with quote
Thanks,
It's exactly what I need.
I knew that CCS is encoding the pin with just one integer, but I was not able to understand the code Embarassed .
Thanks a lot,
Franck.
