delay_us() problem
PostPosted: Sun Feb 04, 2007 12:22 pm     Reply with quote
Here are two functions for a long delay with a variable parameter (16-bit).
long_delay_us():
http://www.ccsinfo.com/forum/viewtopic.php?t=16656
long_delay_ms():
http://www.ccsinfo.com/forum/viewtopic.php?t=375
ice
Thank you
PostPosted: Sun Feb 04, 2007 1:12 pm     Reply with quote
Thank you for your help,PCM.
It now works.
My servo update in now at 70Hz ,I 'm not able to go lower than that(RTCC_DIV_256).It's slow, but it gets it's position right.
In case anyone finds it useful, hobby servo control code:
#include <16F876A.h>
#use delay(clock=20000000)
void long_delay_ms(long count)
long k;
for(k = 0; k <count>0).
int16 sum;
int16 b=20;
output_high(PIN_C0);
sum=400+(b*20);             //change value of b from 0 to 20(1ms to 2ms)
long_delay_ms(sum);        // 400 for 1ms,,600 for 1.5ms,800 for 2ms
output_low(PIN_C0);
set_timer0(0);
setup_timer_0( RTCC_INTERNAL | RTCC_DIV_256 );
