Contador and TIMER0 in C
PostPosted: Sun Sep 25, 2005 2:57 pm     Reply with quote
Here is sample code to generate a RTCC interrupt every 10 ms.
#include <16F628A.H>
//#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, ERRORS)
int8 interrupt_flag;
// The rtcc interrupt occurs when the rtcc rolls over
// from FF to 00.
// RTCC interrupt rate =
//   Fosc / (4 * rtcc pre-scaler * rtcc pre-load)
//   = 4 MHz / (4 * 256 * 39)
//   = 100.16 Hz
// This gives us a timer tick approx. every 10 ms
// (9.98 ms actually).
#define RTCC_PRELOAD (256 - 39)
#int_rtcc
void rtcc_isr(void)
set_rtcc(RTCC_PRELOAD);
interrupt_flag = 1;
// Setup the RTCC to increment at a rate of 3906.25 Hz.
// Then set the preload to 39 so that it will roll over
// after 39 clocks, which gives a 100 Hz interrupt rate.
setup_counters(RTCC_INTERNAL, RTCC_DIV_256);
interrupt_flag = 0;
enable_interrupts(INT_RTCC);
// Create a 1 ms pulse each time the interrupt flag is set
// by the int_rtcc routine.
   if(interrupt_flag == 1)
      output_high(PIN_B1);
      delay_ms(1);
      output_low(PIN_B1);
      interrupt_flag = 0;   // Then clear the flag
respected
PostPosted: Thu Nov 17, 2005 12:17 pm     Reply with quote
very thanks
