need help for rotary encoder
Goto page Previous  1, 2
cybanical
thanks
PostPosted: Tue Apr 15, 2008 10:00 am     Reply with quote
Great, thanks for the direction, that makes sense. I found the memory organization charts in the data sheets (table 5.1 for the 18f4520), I had looked before but didn't really know what i was looking for.
I made an R/2R ladder last night and managed to turn my encoder into a pot. Next for me is to determine velocity and turn that into a velocity.
cybanical == cyber+mechanical
EC
Rotary Encoder (Fast and Slow Mode)
PostPosted: Tue Aug 26, 2008 10:06 am     Reply with quote
Ttelmah wrote:
int16 position;
#int_global
void myint(void) {
   static int old;
   static int new;
   static int value;
   //Here I have an edge on one of the quadrature inputs
   new=portb;
   /*Now I have to decode the quadrature changes. There are four
   possibilities:
   I can have a rising or falling edge, on each of the two inputs. I have to
   look at the state of the other bit, and increment/decrement according to
   this. */
   value=new^old;
   //'value', now has the bit set, which has changed
   if (value & 0x10) {
      //Here the low bit has changed
      if (new & 0x10) {
         //Here a rising edge on A
         if (new & 0x20) --position;
         else ++position;
      else {
         //Here a falling edge on A
         if (new & 0x20) ++position;
         else --position;
   else {
      //Here the high bit (B) must have changed
      if (new & 0x20) {
         //Here a rising edge on B
         if (new & 0x10) ++position;
         else --position;
      else {
         //Here a falling edge on B
         if (new & 0x10) --position;
         else ++position;
   old=new;
   bchanged=0;
#asm
   //Here the 'fast' exit.
   RETFIE  1
#ENDASM
I'm use a rotary encoder switch from ALPS (EC12 series) and the code from Ttelmah works perfectly with it! But, I'd like have two levels when I'm increase or decrease a counter variable.
Like this: in Normal(slow) mode, I'm increase/decrease per one unit and in Fast mode, per ten units.
How can I change the code to do what I want?
Thanks in advance,
EC
PostPosted: Tue Aug 26, 2008 10:23 am     Reply with quote
You would need to do something like:
int16 position;
int1 big_increment=FALSE;
#int_global
void myint(void) {
   static int old;
   static int new;
   static int value;
   new=portb;
   possibilities:
   this. */
   value=new^old;
   if (value & 0x10) {
      if (new & 0x10) {
         if (new & 0x20) {
              if (big_increment) position-=10;
              else --position;
         else {
              if (big_increment) position+=10;
              else ++position;
      else {
         if (new & 0x20) {
              else ++position;
         else {
              else --position;
   else {
      if (new & 0x20) {
         if (new & 0x10) {
             else ++position;
         else {
             if = (big_increment) position-=10;
             else --position;
      else {
         if (new & 0x10) {
             else --position;
         else {
             else ++position;
   old=new;
   bchanged=0;
#asm
   RETFIE  1
#ENDASM
Then set 'big_increment' to true when you want the fast increment, and false, when not.
This will slightly reduce the maximum speed the encoder can be handled, but for a normal rotary wheel shouldn't matter.
EC
PostPosted: Tue Aug 26, 2008 10:44 am     Reply with quote
Hi Ttelmah,
First, thanks for your quick answer.
I understand the principle with "big_increment" but at which moment must I set or clear this flag?
Best regards,
EC
PostPosted: Tue Aug 26, 2008 2:56 pm     Reply with quote
When you want the larger increment.....
You have not said how you want to trigger this. I'd assume you are going to use a button or something?.
EC
PostPosted: Tue Aug 26, 2008 3:27 pm     Reply with quote
Maybe, a little more explain to what I'm working is welcome Smile
I'd made a Countdown Timer with a rotary encoder switch (EC12 from ALPS) and a relay.
I have also two buttons: one for start/stop and other one for Reset timer.
The principle of "Fast" and "Slow" mode then I'd like reproduce, It's like the "big button" of a generator functions to choose the Frequency. In this case, if you turn slowly, it's increment/decrement per unit but if you turn faster, it's increment/decrement per 10 or whatever without triggered with a button.
I hope You see my goal with the rotary encoder.
Best Regards,
EC
Page 2 of 2
