How restart wdt using Timer2
aasanchez
PostPosted: Thu Aug 22, 2013 4:41 pm     Reply with quote
I have a small circuit which is something basic, I get a information via xbee and I relay via rs485, both devices are connected to the same UART port, a 18F4520, I noticed that when connecting two transmitters the pic works so wrong, restarts, and crashes, does not work, once I happened something similar and solved using the wdt, and since that time had a ds1307, performed the restart_wdt () i2c communications, however this time I have the same problem but I have not nothing to communicate via i2c, I thinking of making the restart_wdt (), using one of the timers, but this I was unable to apply it correctly, someone can help me or show me some code where using a timer to run the restart_wdt (). .. thanks for your attention ..
asmboy
PostPosted: Thu Aug 22, 2013 6:38 pm     Reply with quote
start by showing your code with an explanation of what is failing.
a link to the schematic is not a bad idea either.
PostPosted: Thu Aug 22, 2013 9:03 pm     Reply with quote
See Mistake #2 in the link below:
http://betterembsw.blogspot.com/2010/06/top-two-mistakes-with-watchdog-timers.html
