Help w/ #bit please SOLVED
wayneosdias
PostPosted: Tue Sep 16, 2008 2:17 pm     Reply with quote
Using PCH4.078 PIC18F4423
declared in header:
#bit CKE  = 0xFC7.6
#define TRUE 1
in app:
CKE = TRUE;
While the above compiles fine, it doesnt execute correctly in circuit. This dosnt work as well:
CKE = 1;
The only way I can get it to execute correctly is to set CKE as follows:
output_high(CKE)
What is interesting is that the 2 uppermost blocks of code compile and execute correctly on the 18F2523, the 28pin version of the 18F4423. What am I doing wrong?
PostPosted: Tue Sep 16, 2008 2:37 pm     Reply with quote
output_high(CKE)
This will never work. The output_high() function expects a parameter in
the CCS pin number format.
I suspect that you really mean the output_bit() function. But that function
takes two parameters.
You need to post a real test program, and don't "type in" code into your
post. Copy and paste a short, compilable test program into a post.
wayneosdias
PostPosted: Tue Sep 16, 2008 2:45 pm     Reply with quote
PCM programmer wrote:
output_high(CKE)
Interestingly it does work as I posted. I contemplated the output_bit Fx, but I thought I needed the first parameter to be a byte and then just index the bit.
What exactly should my small program demonstrate? I am in the middle porting a significantly large (working)program.
Pardon my ignorance.
PostPosted: Wed Sep 17, 2008 2:46 am     Reply with quote
Both the CKE=1, and CKE=TRUE statements correctly set the bit you want. Simply look at the assembler...
Using 'output_high', is definitely wrong, and liable to be doing things you don't expect. In fact the code generated for this, is remarkably complex. It starts by setting the CKE bit, then updates registers FE8, FE9, FEA, and FEF. It actually ends up turning off the CKE bit before it exits. It by default, is designed to update the associated 'TRIS' register, and becaue the value you are giving it is wrong, this goes completely 'screwy', and results in a whole lot of registers being changed...
If this works, it says two things:
1) Luck....
2) You don't actually want CKE turned on...
wayneosdias
PostPosted: Wed Sep 17, 2008 8:55 am     Reply with quote
Yes you are correct, I had an #IFDEF setting CKE to a diff value for a diff app w/o a closing #ENDIF, so the output_high was actually killing it allowing the spi to work as intended.
The code I'm working with has a lot of redundancy, continually resetting already set bits. Going through and commenting them out also resolved the problem.
