18f4550 AND TIMERS
madeiras
18f4550 AND TIMERS
PostPosted: Mon Sep 15, 2008 10:08 am     Reply with quote
Hello everybody!
I need help once more, I have a external interrupt, (INT_EXT2). I want to do the following: The PIC must wake from minute to minute and do the interrupt code, but I don´t know how to do it. Wake every minute and do the code in interrupt.
In my code i have this:
#include <18F4550.h>
#DEVICE ADC=8
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#include <usb_cdc.h>                                                            //USB CALL
/********************************** LCD ***************************************/
#define RS_LCD  PIN_D1
#define CSB_LCD  PIN_D0
#bit IDLEN=0xFD3.7 //SLEEP MODE
unsigned char valorADC;
unsigned char RB2;
unsigned char RB3;
unsigned char MSB;
unsigned char controlo;
unsigned char string[18];
unsigned char tempoSleep;
unsigned char modo_Vref; //VREF a guardar na memória EEPROM da PIC
Unsigned char canal_1,canal_2,canal_3,canal_4,canal_5,canal_6,canal_7,canal_8; //Canais a amostrar
unsigned char canal1,canal2,canal3,canal4,canal5,canal6,canal7,canal8;
unsigned char auxcanal1,auxcanal2,auxcanal3,auxcanal4,auxcanal5,auxcanal6,auxcanal7,auxcanal8; //variáveis auxiliares para guardar tempos amostragem
#INT_EXT2 // External interrupt #2
   void temp_amostras()
      if(canal1==0)
         auxcanal1 = canal1;
         //guarda na EEPROM os dados
      if(canal2==0)
         auxcanal2 = canal2;
      if(canal3==0)
         auxcanal3 = canal3;
      if(canal4==0)
      auxcanal4 = canal4;
      if(canal5==0)
         auxcanal5 = canal5;
      if(canal6==0)
         auxcanal6 = canal6;
      if(canal7==0)
         auxcanal7 = canal7;
      if(canal8==0)
         auxcanal8 = canal8;
      auxcanal1--;auxcanal2--;auxcanal3--;auxcanal4--;auxcanal5--;auxcanal6--;auxcanal7;auxcanal8--;
void main(){
   enable_interrupts(INT_EXT2);
   ext_int_edge( 2,H_TO_L ); // Nivel lógico da interrupção
   IDLEN=1;
   //*********************EEPROM************************************************
   if(read_eeprom(0x00)==0xFF){
      modo_Vref=5;
   else{
   modo_Vref=read_eeprom (0x00);
   lcd_clear();
   potDigital(modo_Vref);//teste
   setup_adc_ports(AN0_TO_AN7|VSS_VDD);
   setup_spi(SPI_MASTER|SPI_H_TO_L|SPI_XMIT_L_TO_H|SPI_CLK_DIV_64);
   output_high(CS_ADC); //CS ADC externo a 1
   start_ds1305();
   lcd_setup();
  //----------------------------------MENUS-------------------------------------
   do
   menu_inicial();
   menu_aux();
   if (tempoSleep==1)
      sleep();
   }while(true);
PostPosted: Mon Sep 15, 2008 3:19 pm     Reply with quote
Do you have a signal on the INT2 pin of the 18F4550 that has a
rising edge once per minute ? Describe the signal on the INT2 pin.
What is the frequency of this signal ?
madeiras
PostPosted: Tue Sep 16, 2008 7:14 am     Reply with quote
I want to plug to INT2 PIN an RTC (http://datasheets.maxim-ic.com/en/ds/DS1305.pdf). My RTC has 2 alarms, but i only can define an hour to him wakeup. I want that he give a signal every minute to INT2 PIN, but i don´t know to do it.
I´ve read about timers of PIC. I could use them instead? But I don´t know how to put them given an interrupt every minute.
Tk´s, I'm new on these things, and I'm learning by myself using this!
