Trivial string problem
SherpaDoug
PostPosted: Wed Jun 04, 2008 9:24 am     Reply with quote
In years of working with PICs and CCS I have never had to use strings until now. This code is almost verbatim from my beginning C primer. It prints "Hello Small_Strings" and "This is a quoted string" but it prints nothing for globalstring.
What am I doing wrong? Is it some peculiarity of PICs or CCS? I suspect I am not declaring the string correctly.
I am using PCW 3.242 with a PIC18F2585.
char globalstring[] = "This is a global string.";
   output_high(PWR_485);
   fprintf(Gliderbus,"Hello Small_Strings\n\r");
   while(1){
      fprintf(Gliderbus,"This is a Quoted String\n\r");
      fprintf(Gliderbus,"%s", globalstring);
Output:
Hello Small_Strings
This is a Quoted S.......
PostPosted: Wed Jun 04, 2008 10:11 am     Reply with quote
I installed vs. 3.242 and ran the following program in MPLAB Simulator.
It works. It displays this in the Output window:
Hello Small_Strings
#include <18F2585.h>
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP, NOPBADEN
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=Gliderbus)
SherpaDoug
Stranger & stranger...
PostPosted: Wed Jun 04, 2008 12:23 pm     Reply with quote
Thanks PCM, but here is my output and the exact code I am now running, mostly your code with minimum changes for my hardware:
Hello Small_Strings
Thi
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP, NOPBADEN
#use delay(clock=8000000)
#define PWR_485   PIN_C3
#use rs232(baud=1200, xmit=PIN_C6, rcv=PIN_C7, ERRORS, stream=Gliderbus, enable=PIN_B3)
   while(1){
I even ran it real slow (600 baud) to see if the global string was being overwritten. How can "Quoted String" print, but "global string" not print?
PostPosted: Wed Jun 04, 2008 12:57 pm     Reply with quote
There's a problem with using the Enable pin with printf or fprintf in your
version of the compiler. This problem is fixed in later versions.
This thread discusses some work-arounds:
http://www.ccsinfo.com/forum/viewtopic.php?t=28433
SherpaDoug
PostPosted: Wed Jun 04, 2008 1:19 pm     Reply with quote
Wow, thanks! It would have taken me forever to find that. The work around is simple, almost elegant.
It is so good to find it's not pilot error Very Happy
