H Guest
Request for help in C coding |
Posted: Wed Apr 02, 2008 10:36 pm |
Hi, i m Helen.
Need some help in my project.
I need to design a circuit with coding which voltage as input to tell the pic16f877a to record the time. Then 3 timing is record and calculation will be do after that.
In the simulation i can run the code correctly. However, in pratical i can't get what i want.
The code below:
#include <16F877A.h>
#device ADC=10
#device icd=true
#fuses NOWDT,HS, PUT, NOPROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#include <STDLIB.H>
#include <math.h>
#include <lcd.c>
#define Full 500 //in mili litre
#define INTS_PER_SECOND 76 // (20000000/(4*256*256))
BYTE seconds; // A running seconds counter
BYTE int_count; // Number of interrupts left before a second has elapsed
#int_rtcc // This function is called every time
void clock_isr() { // the RTCC (timer0) overflows (255->0).
// For this program this is apx 76 times
if(--int_count==0) { // per second.
++seconds;
int_count=INTS_PER_SECOND;
void main(){
float input_num;
float conv_num;
int i;
BYTE T1;
BYTE T3;
BYTE T4;
BYTE Time_full;
float Cap_per_Sec;
BYTE Total_time;
float Total_capacity;
port_b_pullups(TRUE);
set_tris_b(0xFF);
setup_adc_ports(RA0_RA1_ANALOG_RA3_REF);//AN0);
set_adc_channel(0);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
set_timer0(0);
setup_counters( RTCC_INTERNAL, RTCC_DIV_256 | RTCC_8_BIT);
enable_interrupts(INT_RTCC);
lcd_init();
i=3;
T1=0;
T3=0;
T4=0;
do {
input_num=Read_ADC();
conv_num=input_num/204.599;
if (conv_num<1.5 && conv_num>1.0 && T1==0){
T1=seconds;
i=i-1;
printf(lcd_putc,"%u", T1);
if (conv_num<3.0 && conv_num>2.5 && T3==0){
T3=seconds;
i=i-1;
printf(lcd_putc," %u", T3);
if (conv_num<4.5 && conv_num>4.0 && T4==0){
T4=seconds;
i=i-1;
printf(lcd_putc," %u Cap:\n", T4);
}while(i>0);
// printf(lcd_putc,"%u %u %u\n", T1, T3, T4);
Time_full=T4-T3;
Cap_per_Sec=Full/Time_full;
Total_time=T4-T1;
Total_capacity=Cap_per_Sec*Total_time/1000;
printf(lcd_putc,"%1.4f liter", Total_capacity);
Can anyone solve this problem or give some advise, please.
Thank You.
Sincerely,
Helen
[/code] |
Matro Guest
Posted: Thu Apr 03, 2008 1:28 am |
First, notice that your code is not endless. So if i <= 0 then your program will exit and the PIC will stop.
My second advise is : indent and comment your code (in english).
That is definitely "unreadable" for us, but maybe for you too...
To debug this program you can comment everything except the first part of the main and test it. If it works fine, uncomment the second part and test again. And so on...
Matro. |
Wayne_
Posted: Thu Apr 03, 2008 1:32 am |
You included the /code tag but forgot the first code tag
Anyway, do you get any results ? |
Posted: Thu Apr 03, 2008 1:51 am |
You forgot to set she seconds variable to zero at program start. |
Posted: Thu Apr 03, 2008 2:37 am |
Also, read the data sheet about ADC clocks.
ADC_CLOCK_INTERNAL, should _not_ be used on this chip, above 1MHz, unless the processor is put to sleep for the conversion. It is in the notes under table 11-1. You need to be using the /32 ADC clock instead. Generally simulators, won't realise that this is wrong, and will give good results, but on the real chip, it results in really wayward ADC readings.
Re: Request for help in C coding |
Posted: Thu Apr 03, 2008 4:20 am |
H wrote: | Hi, i m Helen.
The code below:
#device ADC=10
#device icd=true
#include <STDLIB.H>
#include <math.h>
#include <lcd.c>
++seconds;
void main(){
float input_num;
float conv_num;
int i;
BYTE T1;
BYTE T3;
BYTE T4;
BYTE Time_full;
float Cap_per_Sec;
BYTE Total_time;
set_tris_b(0xFF);
set_adc_channel(0);
setup_spi(FALSE);
set_timer0(0);
lcd_init();
i=3;
T1=0;
T3=0;
T4=0;
do {
if (conv_num<1.5 && conv_num>1.0 && T1==0){ //if volt i/p in this
range
T1=seconds; // T1 second is record
i=i-1;
if (conv_num<3.0 && conv_num>2.5 && T3==0){ //if volt i/p in this
range
T3=seconds; // T3 second is record
i=i-1;
if (conv_num<4.5 && conv_num>4.0 && T4==0){ //if volt i/p in this
range
T4=seconds; // T4 second is record
i=i-1;
}while(i>0); //for a process, i jz need sense 3 time voltage
change. then if will that the 3 timer to do
calculation
Time_full=T4-T3;
Total_time=T4-T1;
Thank You.
Sincerely,
Helen
[/code] |
Posted: Thu Apr 03, 2008 4:36 am |
H wrote: |
Sorry I till not sure how to sent a post.
Really thanks for fellow friends suggestion. I will try every one to find the solution.
However, i try to write the comment nicely so it can be read but it till change after I post it.
Actually which seconds variable that you that forget to set to zero?
What mean by first code tag?
Sorry for my poor English and understanding.
For the ADC_CLOCK_INTERNAL problem, I really not notice about it. Give some time to understand it.
Really thank you all.
Sincerely,
Helen
[/code] | [/quote] |
Matro Guest
Posted: Thu Apr 03, 2008 5:11 am |
The variable called "seconds" is never initialized.
in your first post, you place a "[/code]" at the end but forgot to place the "[code]" tag at the beginning.
Matro. |
tyhon Guest
Posted: Sat Apr 12, 2008 7:23 am |
you can post circuit? |
Humberto
Posted: Sat Apr 12, 2008 8:11 am |
If you can simulate the preceding code successfully but not with a real hardware, it is
a good practice for a beginner to start with a tested hardware. You can arrange a basic
hardware with a running MCU + 1 blinking LED. This will give you a close aproach that
the MCU is running doing its basics functions and the whole hardware is OK.
Then you should add a new function in each step, doing some tests and debugging until
it run as expected and so on.
Regarding your posted messages, before click in the Submit button, pls try the Preview
button to see how it will look once posted.
Humberto |
Interrupt problem?? |
Posted: Wed Apr 16, 2008 3:35 am |
Hi!
I still dealling with the same problem. I trying to post the circuit on but I till finding the way to do so.
However, I test the coding part by part. Till the same situation where the timing till display zero. Even I write in most simple coding already.
do{
if(conv_num<1.5 && conv_num>1){
T1=seconds;
printf(lcd_putc," %u", T1);
}while(i>0);
Can I ask? I am not using RS232, then can I till using the interrupt function - #INT_RTCC? Since, the PIC can't sense the seconds and always zero. Or it is my circuit problem?
Sincerley,
helen |
