Trouble with simple I/O on pic16f88
Mike M
PostPosted: Fri Mar 14, 2008 3:23 am     Reply with quote
I´m newbie in programming pics, and I´m having some trouble with a pic16f88. As a first test, I wanted to see if I could make output pins in diferent ports toggle high and low.
What I have noticed is that everything works fine in portB but it does nothing on portA. I´m using an external cristal oscilator on ports A7 and A6, can this be the problem?
The version of the complier is 4.016.
Thanks for your help
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Mar 14, 2008 3:34 am     Reply with quote
first: can you post your simple test program? The guys here can give you more useful hints and tips when they see your code.
second: the compiler v4.016 is known to be buggy, in fact all compiler before v4.020. Maybe you can update your compiler?
PostPosted: Fri Mar 14, 2008 4:34 am     Reply with quote
OK, here´s my code:
#include <16f88.h>
#fuses xt,NOWDT,noput,noprotect,nomclr,NOBROWNOUT,nolvp
#include <ctype.h>
#use DELAY(clock=4000000)
#use fast_IO(A)
main()
//port_a_pullups(true);
SETUP_ADC_PORTS(NO_ANALOGS);
SETUP_ADC(ADC_OFF);
set_tris_b(0x00);
output_high(PIN_A0);
output_high(PIN_A1);
output_high(PIN_A2);
 //set port b as outputs
         output_low(PIN_A0);
         output_low(PIN_B7);
         output_high(PIN_B7);
         output_low(PIN_A1);
         output_low(PIN_A2);
So, for portB the pin toggles right but for portA it does nothing.
Mike M
I solved it!
PostPosted: Fri Mar 14, 2008 5:23 am     Reply with quote
Finally I solved the problem.
It´s a RMW problem, I fixed it shadowing the port as it says in one of the old posts
Thanks to all!
