I was wondering if anyone had any header files for I2C timing using the 18F4520 that I might be able to use? I'm pretty new to programing PICs, so if anyone could give me a brief description of what I2C timing is and how it works, that would also be very beneficial, thanks
rnielsen
Posted: Tue Nov 27, 2007 9:27 am
First of all, not to look lazy(well, lazier than I really am) do a search on the forum here. There are boat loads of posts regarding I2C communications. I2C is pretty much the same regardless of what part you're using. Timing might differ depending on what speed your master/slave is running at. There are posts regarding that too.
Once you've searched and tinkered a bit then come back with a sample of what you've tried. There are many people here that are willing to help. They just won't do everything for you. You need to put in a little effort first.(like searching first and then asking questions regarding what you've found, if you still don't understand).
Ronald
treitmey
