I have managed to set up timer1 as an external timer so that I can put the PIC to sleep and wake up with a 32kHz crystal.
I also would like to be able to use the external interrupt to wake the PIC up from sleep.
Basically when I enable the Gloabl Interrupt the PIC no longer wakes from sleep. I have not set the Global Interrupt bit as I am using the Int Peripheral Bit for the timer1 module.
Does anyone know what may cause the interrupt to stop woking when I put it to sleep?
Posted: Tue Sep 25, 2007 6:33 am
Setting the global interrupt flag means you will have to add a timer1 interrupt handler as well or the timer1 flag will never get cleared and your PIC hangs.
sjharris
Posted: Tue Sep 25, 2007 7:01 am
I just found that out!!
Thanks for reply. It is (fingers crossed) working now!!
Steve
