I2C Communication Between Two pic18f4685's
Tim Klassen
PostPosted: Wed Aug 22, 2007 4:13 pm     Reply with quote
I have spent several days trying hookup two pic18f4685's via I2C, different code has allowed me to hookup to a DS1631. Can someone show me where I have gone wrong? I am using IDE 4.010, have two 4.7k pullup resistors and have sda to sda and scl to scl hooked up.
Master Code:
#include "E:\Misc\CCS\CNC\CNC.h"
#include "E:\Misc\CCS\CNC\Flex LCDx4.h"
#use I2C(master, sda=PIN_C4, scl=PIN_C3)
int BoardAddress;
while (TRUE){
BoardAddress=0xa0;
delay_ms(150);
i2c_start();
i2c_write(BoardAddress); //Address
delay_ms(15);
i2c_write(20);
delay_ms(15);
i2c_stop();
Slave Code:
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xa0)
BYTE address = 0;
#INT_SSP
void ssp_interupt ()
address=1;
void main ()
enable_interrupts(INT_SSP);
lcd_init();
lcd_gotoxy(1, 1);
printf(lcd_putc," Tim ");
while (TRUE) {
lcd_gotoxy(1, 1);
printf(lcd_putc," Tim %u ", address);
Common Code:
#include <18F4685.h>
#device adc=8 //sets if adc return 8 bit or 10 bit
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES BBSIZ4K //4K words Boot Block size
#use delay(clock=32000000) //The delay is wrong
Thank you for your time.
Tim Klassen
PostPosted: Wed Aug 22, 2007 4:41 pm     Reply with quote
Run the Slave at a minimum of 8 MHz (higher is preferred), and try
it with the CCS Ex_Slave.c example code. Use the master code
linked to in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=30905&start=3
I don't know how that relates to the compiler version, but if your compiler
version is 4.010, then you better get a later version. Look at the top of
the .LST file to see your version. The .LST file is located in your project
directory. Vs. 4.010 is too early in the release cycle for vs. 4.
Tim Klassen
PostPosted: Fri Aug 24, 2007 5:51 am     Reply with quote
Hi, I finally have some good news, the program works and I will be able to use it, but I am confused by the order of writing from master to slave:
I am unsure where "14" ends up and why the slave address is sent last. Here is printf output on computer from slave:
data 78 123 160 \0A
states 0 1 2 3 0 128 129 \0A
count 7 \0A \0D
\0D
Master Writing:
i2c_start();
i2c_write(0xA0);
i2c_write(14);
i2c_write(78);
i2c_write(123);
i2c_stop();
Master Code:
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, slow)
int8 data;
setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_PLL_Off);
// Write the letter 'B' to the slave board.
delay_ms( 100 );
i2c_start();
i2c_write(0xA0);
i2c_write(14);
i2c_write(78);
i2c_write(123);
i2c_stop();
// Read from the slave board and display the data.
i2c_start();
i2c_write(0xA0);
i2c_start();
i2c_write(0xA1);
data = i2c_read(0);
i2c_stop();
printf("read %c \n\r", data);
while(1){}
Slave Code:
#byte OSCTUNE = 0xF9B //multiplies processor clock
#bit PLLEN = OSCTUNE.6 //multiplies processor clock
BYTE address, buffer[0x10];
int count = 0;
int state1=0, state2=0, state3=0, state4=0, state5=0, state6=0, state7=0;
int8 data=0, data1=0, data2=0;
#INT_SSP
BYTE incoming, state;
count++;
state = i2c_isr_state();
state7=state6;
state6=state5;
state5=state4;
state4=state3;
state3=state2;
state2=state1;
state1=state;
if(state < 0x80) //Master is sending data
incoming = i2c_read();
if(state == 1){
data = incoming;
if(state == 2){
data1 = incoming;
if(state == 3){
data2 = incoming;
if(state == 0x80) //Master is requesting data
/// i2c_write(buffer[address]);
i2c_write('t');
int tom=0;
//setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_PLL_OFF);
setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_PLL_ON);
//setup_oscillator(OSC_8MHZ|OSC_NORMAL|OSC_PLL_Off);
while(1){
delay_ms( 500 );
printf("data %u %u %u \n\r", data, data1,data2);
printf("states %u %u %u %u %u %u %u \n\r", state7, state6, state5, state4, state3, state2, state1);
printf("count %u \n\r", count);
Using same common files as before.
Corrections required to acheive this output:
1) run slave at 32mhz.
2) delay transmission from master so slave can get booted up.
Master and slave can both send and receive.
Tim Klassen
