problem using CCS in MPLAB (assembler OK)
tquantum
PostPosted: Thu Aug 09, 2007 8:51 am     Reply with quote
Hi all.
I get a problem while using CCS in MPLAB. I don't know why this code does't work? (I have tried the assembler code from .lst with ICD 2, and it works)
Thanks,
tquantum
#include <12F615.h>
#fuses INTRC_IO,NOWDT,NOPROTECT,IOSC8,NOPUT
#use delay(internal=8M)
while( TRUE ) {
OUTPUT_A(0XFF);
PostPosted: Thu Aug 09, 2007 11:02 am     Reply with quote
1. Are you running this program in hardware or the MPLAB simulator ?
2. What's your version of MPLAB ?
3. What's your compiler version ?
tquantum
PostPosted: Thu Aug 09, 2007 5:34 pm     Reply with quote
I have tested the asm type program through ICD2 header, and it works.
but it can't work in C. The version of MPLAB and the CCS are the latest version 7.60a and 4.033, and the plug-in program is downloaded from http://www.ccsinfo.com/downloads.php
