Eeprom_programmer
How to file in a Eeprom |
Posted: Tue Aug 07, 2007 12:19 pm |
I am trying to log the date on a EEPROM, but my code doesn't want to work. Please help me for some reason my rs232 communication doesn't want to work either.
Thanks in advance
#include "16F883.h"
//#include "time.h"
#use DELAY(clock=4000000)
#fuses HS,NOWDT,NOPROTECT,PUT,NOLVP,NOBROWNOUT,NOWRT
#define RS232_XMIT PIN_C6 // (output) RS232 serial transmit
#define RS232_RCV PIN_C7 // (input) RS232 serial receive
#define MAX_TICKS 4
#define OPAMP_GAIN 7.0
#define ANALOG_REF 5.0
#ifndef DAL_SCL
#define DAL_SCL PIN_C3
#define DAL_SDA PIN_C4
#define EE_BLOCK 7
#endif
#case
#use rs232(baud=9600, xmit=RS232_XMIT, rcv=RS232_RCV)
#use i2c(master,sda=DAL_SDA, scl=DAL_SCL)
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
//unsigned int16 ee_address = 0;
//unsigned int16 sensor = 0; // holds ADC value of sensor
//unsigned int16 sensitivity=0 ; // holds ADC value of sensitivity
//unsigned char ticks = 0;
//unsigned char ms = 0;
//unsigned char second = 0;
//unsigned char minute = 0;
//unsigned char Cublice_num = 1;
// Writes to the slave board from the master.
void write_ext_eeprom(int16 address, unsigned char data)
i2c_start();
i2c_write(0xAE);
i2c_write((int8)(address>>8));
i2c_write((int8)address);
i2c_write(data);
i2c_stop();
delay_ms(5);
// Read from the slave board and display the data.
unsigned char read_ext_eeprom(int16 address )
unsigned char data_read;
i2c_start();
i2c_write(0xAE);
i2c_write( (int8)(address>>8));
i2c_write( (int8)address);
i2c_start();
i2c_write(0xAF);
data_read = i2c_read(0);
i2c_stop();
delay_ms(5);
return data_read;
// Data structures
// Data structure for logging
typedef struct
unsigned char dd, // Day
mt, // Month
hh, // Hour
mm, // Minute
ss; // Seconds
unsigned int16 lev; // Fluid Level
} lvlData;
// Level Data structure
lvlData levelData; // Stores info to be logged to EEPROM
// This function will log a single lvlData structure to EEPROM
void logtoEE(unsigned int ee_address, lvlData *currentEntry)
// Move to correct block
ee_address = ee_address * EE_BLOCK;
// Write EEPROM
write_ext_eeprom(ee_address, currentEntry->dd); // Day
write_ext_eeprom(ee_address+1, currentEntry->mt); // Month
write_ext_eeprom(ee_address+2, currentEntry->hh); // Hour
write_ext_eeprom(ee_address+3, currentEntry->mm); // Minute
write_ext_eeprom(ee_address+4, currentEntry->ss); // Second
write_ext_eeprom(ee_address+5, currentEntry->lev >> 8); // Level (High byte)
write_ext_eeprom(ee_address+6, (currentEntry->lev)); // Level (Low byte)
// This function will read a single log from the EEPROM and store it in a lvlData structure
void readEE(unsigned int ee_address, lvlData *currentEntry)
// Read EEPROM
currentEntry->dd = read_ext_eeprom(ee_address); // Day
currentEntry->mt = read_ext_eeprom(ee_address+1); // Month
currentEntry->hh = read_ext_eeprom(ee_address+2); // Hour
currentEntry->mm = read_ext_eeprom(ee_address+3); // Minute
currentEntry->ss = read_ext_eeprom(ee_address+4); // Second
currentEntry->lev = read_ext_eeprom(ee_address+5); // Level (High Byte)
currentEntry->lev = (currentEntry->lev << 8) | (read_ext_eeprom(ee_address+6)); // Level (Low byte)
void setup()
set_tris_a(0x0B); // Port A Direction
// RA0 : Sensor Input (1)
// RA1 : Sensitivity Input (1)
// RA2 : Not used (0)
// RA3 : Not used (1)
// RA4 : Not used (0)
// RA5 : Not used (0)
set_tris_b(0x00); // Port B Direction
// RB0 : Not used (0)
// RB1 : RS-485 Direction Output (0)
// RB2 : LED1 Output (0)
// RB3 : LED2 Output (0)
// RB4 : LED3 Output (0)
// RB5 : RUN LED Output (0)
// RB6 : Not used (0)
// RB7 : Not used (0)
set_tris_c(0x80); // Port C Direction
// RC0 : Not used (0)
// RC1 : Not used (0)
// RC2 : Relay Output (0)
// RC3 : SCLK (0)
// RC4 : SDAT (0)
// RC5 : Not used (0)
// RC6 : Serial Transmit (0)
// RC7 : Serial Receive (1)
// ADC Setup
//enable all interrupts (else timer2 wont happen)
struct lvlData *currentEntry;
unsigned char i;
setup();
for(i = 1 ; i <10; i++)
levelData.dd = 1;// Day
levelData.mt = 2; // Month
levelData.hh = 3; // Hour
levelData.mm = 4; // Minute;
levelData.ss = 5;
levelData.lev= 6;
logtoEE(i , i);
readEE (i , i);
printf( " \nDag %d" , currentEntry->dd); // Day
printf( " \nMaand %d" , currentEntry->mt); // Month
printf( " \nUur%d" , currentEntry->hh); // Hour
printf( " \nMinute%d" , currentEntry->mm); // Minute
printf( " \nSekondes%d" ,currentEntry->ss); // Second
//printf( " \nLev1 %d" , currentEntry->lev); // Level (High Byte)
//printf( " \nLev2 %d" , currentEntry->lev); // Level (Low byte)
Eeprom_programmer
Posted: Tue Aug 07, 2007 2:48 pm |
Thx the RS232 works but the eeprom doesn't any ideas?
#include "16F883.h"
//#include "time.h"
#define MAX_TICKS 4
#ifndef DAL_SCL
#define EE_BLOCK 7
#endif
#case
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
i2c_start();
i2c_write(0xAE);
i2c_write(data);
i2c_stop();
delay_ms(5);
i2c_start();
i2c_write(0xAE);
i2c_start();
i2c_write(0xAF);
i2c_stop();
delay_ms(5);
return data_read;
// Data structures
typedef struct
mt, // Month
hh, // Hour
mm, // Minute
ss; // Seconds
} lvlData;
// Write EEPROM
// Read EEPROM
void setup()
// RC3 : SCLK (0)
// RC4 : SDAT (0)
// ADC Setup
unsigned char i = 0;
setup();
printf( " \n Die datum " );
delay_ms(50);
levelData.ss = 5;
levelData.lev= 6;
logtoEE(i , i);
readEE (i , i);
Posted: Tue Aug 07, 2007 3:03 pm |
Code: | logtoEE(i , i);
readEE (i , i); | The second parameter is wrong in both calls. |
Eeprom_programmer
Posted: Tue Aug 07, 2007 3:05 pm |
Thx, but can you maybe give me a hint to what it must be becaues i am trying to understand this, but it is hard. |
Posted: Tue Aug 07, 2007 3:19 pm |
Try the changes below (not tested)
Code: | void main()
int8 RecordNr; // Moved the variable declarations out of the loop.
// And I like int8 better as it is easier to port to other compilers.
struct lvlData currentEntry; // removed the '*' because you do not want a pointer but have to reserve memory.
setup(); // moved out of loop for optimization.
RecordNr = 0;
// delay_ms(50); no delay required here
levelData.dd = 1; // Day
levelData.ss = 5;
levelData.lev= 6;
logtoEE(RecordNr, &levelData); // A '&' indicates the compiler we want to pass the address of the struct
readEE (RecordNr, ¤tEntry);
// Because we changed the declaration of currentEntry, we had to change the data access below from '->' to '.'
printf( "\nDag %d", currentEntry.dd); // Day
printf( "\nMaand %d", currentEntry.mt); // Month
printf( "\nUur %d", currentEntry.hh); // Hour
printf( "\nMinuut %d", currentEntry.mm); // Minute
printf( "\nSeconde %d", currentEntry.ss); // Second
Eeprom_programmer
Posted: Tue Aug 07, 2007 4:19 pm |
Thanx very much for the help, i understand a lot better now, still i get this errors
--- Info 300 "P:\main1.c" Line 83(2,9): More info: First Declaration of lvlData
*** Error 31 "P:\main1.c" Line 175(18,25): Identifier is already used in this scope
it has something to do with
struct lvldata currentEntry
when i change it to
struct lvldata *currentEntry
it works but returns the wrong values.
Sorry to bother |
SET
Posted: Tue Aug 07, 2007 4:39 pm |
'levelData' declaration is missing:
Code: | struct lvlData currentEntry;
struct lvlData levelData; |
Eeprom_programmer
Posted: Wed Aug 08, 2007 5:06 am |
Thx, but that only seems to create more errors... |
Posted: Wed Aug 08, 2007 6:09 am |
My mistake (I said I didn't test it)
Forget the well intended suggestion from SET. In my posted main(), change Code: | struct lvlData currentEntry; | to Code: | lvlData currentEntry; |
SET
Posted: Wed Aug 08, 2007 6:17 am |
Oops, I didnt see levelData declared further up, I only looked at the snippet in 'main' |
Eeprom_programmer
Posted: Thu Aug 09, 2007 3:13 am |
So now i have both
lvlData levelData
No error anymore - Thank you very much!
But the only value that is returned is -1
Any futher ideas would be greatly apreciated
Thank for all the help up to here! |
Posted: Thu Aug 09, 2007 3:55 am |
What is your compiler version?
Where do you see the -1 values? |
eeprom_programmer* Guest
Posted: Thu Aug 09, 2007 8:26 am |
when i printf dd,hh,mt,ss etc.
My compiler version is V4.033
dd = -1
hh = -1
etc |
Eeprom_programmer
Posted: Thu Aug 09, 2007 8:27 am |
Sorry i wasn't logged in.
The values being displayed here returns -1 values |
