Project file version control
Martin Berriman
PostPosted: Wed Mar 14, 2007 11:36 am     Reply with quote
Am I the only one who is slightly annoyed when each time I open a project, the project file is modified whether I change anything or not. Even if I just open the project to check the contents of a file, the IDE modifies the project file.
I keep my projects under version control (including the project file) and therefore once I have opened one, version control rightly flags it has having changed. I therefore have to recover an unedited version from version control in order to tidy things up again.
Other IDEs that I use for other tasks do not show the same 'feature' Rolling Eyes
Is there some setting which I should set to prevent this? I'm mostly using Version 4 now although it did the same in version 3.
grasspuddle
PostPosted: Fri Mar 16, 2007 7:51 am     Reply with quote
It probably has a 'last opened' data so whenever you open it, a new date is entered making the file appear as changed. Dont think you can really do to much if thats the case.
Martin Berriman
PostPosted: Fri Mar 16, 2007 8:25 am     Reply with quote
Just checked and the actual contents of the file are identical (including white space and everything) - the only thing that changes is the file date and time. Rolling Eyes
