external eprom extrange read problem
itzalak2
PostPosted: Mon Mar 05, 2007 5:15 am     Reply with quote
Hi everybody.
I have an application where I read an external I2C eprom 24AA1025 (1Mega) . I have this read routine
int32 leer_int32_ext_eeprom_banco_0(EEPROM_ADDRESS_H address_h, EEPROM_ADDRESS_L address_l)
int1 ack;
i2c_start();
ack = i2c_write(0b10100000);
delay_ms (10);
i2c_stop();
if (ack==0)
int8 i;
int32 temporal=0;
int32 puntero=0;
i2c_start();
delay_ms (10);
i2c_write(address_h);
delay_ms (10);
i2c_write(address_l);
delay_ms (10);
i2c_start();
i2c_write(0b10100001);
delay_ms (10);
for(i = 0; i < 4; ++i) //secuencial
*(&temporal + i) = i2c_read();
delay_ms (100);
i2c_stop();
return temporal;
and in the main program I read 3 different memory positions:
delay_ms(10);
maniobra_NS1=leer_int32_ext_eeprom_banco_0 (0x00,0x00);
delay_ms(10);
maniobra_NS2=leer_int32_ext_eeprom_banco_0 (0x00,0x04);
delay_ms(10);
maniobra_EW1=leer_int32_ext_eeprom_banco_0 (0xFF,0xFC);
If I read the 3 registers the first and the second returns a correct value but not the last.
If I erase the first and secodn read (maniobra_NS1 and maniobra_NS2) I the returned value of the 3th read is correct.
Any idea why happens it?
Thanks a lot.
I'm using pic 18f2525 and software I2c (I can't use hardware I2c becouse system hangs at init (don't know why)
Thanks again
PostPosted: Mon Mar 05, 2007 11:16 am     Reply with quote
delay_ms (100);
i2c_stop();
You are doing 4 i2c read operations. The last one must do a "NAK".
In CCS, this is done by using a 0 parameter. Example:
c = i2c_read(0);
You need to modify your code above, so the last i2c read does a NAK.
