Joined: 16 Oct 2006 Posts: 110 Location: HOVE, EAST SUSSEX
Help with EX_GLCD.C
Posted: Thu Dec 14, 2006 10:53 am
Hi Guys
This is the first time i am attempting to run the example programme
EX_GLCD.C for a 64x128 samsung KS0108 chipset put the glcd just displays garbage.
my connections the to GLCD are as follows
PIC GLCD(PINS)
E2 CS1 >1
E1 CS2 >2
XXX GND >3
XXX +5V >4
XXX Vo >5
C1 RS > 6
C0 R/W
E0 EN
D7 - D0 connects to DB7 - DB0
RST > +5V
And i changed GLCD.C as follows
Those two lines contradict each other. The driver wants the RST pin
on the GLCD to go to a PIC pin. You have it connected to +5v.
treitmey
Posted: Thu Dec 14, 2006 12:50 pm
I think your command data pin is what you call RS.
You've got it connected, so try it and find out. Shouldn't hurt anything.
BOB_SANTANA
Posted: Thu Dec 14, 2006 1:40 pm
Thanks Guys for the help
I have just followed your advice and it is now working fine
i had to use the following defines as you suggested
Wow this is fun
C is the king i should have started using it years ago
learnt alot from you all.
i am going to try and write a few messages to the display and see
i am a bit confuse though as my rst line is connected to 5v 0n my proton
development board
i tried i put an attachment with this post but i couldn't to show you what i mean _________________ BOB_Santana
