PIC18lf2520 Setting the fuses to use Internal OSC
cam_male2003
PostPosted: Fri Aug 11, 2006 11:29 am     Reply with quote
Hi all:
Anyone know how to configure a pic18lf2520 to use the internal Crystal?
Shocked
PostPosted: Fri Aug 11, 2006 11:50 am     Reply with quote
Load the 18F2520.H file in your editor. Scan the list of available fuse
settings (config bit settings) at the top of the file. CCS tries to use
abbreviations for the config bits that seem reasonable.
What fuse settings do you see in the list that look like they refer to
the internal oscillator ?
cam_male2003
PostPosted: Wed Aug 30, 2006 5:38 am     Reply with quote
I was refering to using the internal Xtal on the chip.
PostPosted: Wed Aug 30, 2006 5:55 am     Reply with quote
There is no internal XTAL, only an internal RC oscillator.
As PCM said above, which of the fuses appear to look like an INTernal RC oscillator fuse?
PostPosted: Wed Aug 30, 2006 7:16 am     Reply with quote
Use INTRC or INTRC_IO in #fuses and don't forget to set up your internal oscillator by
setup_oscillator(OSC_8MHZ | OSC_INTRC);
as the first line of your main() code because this chip has two internal oscillators (8MHz and 31kHz).
cam_male2003
JUST THANKING EVERYONE
PostPosted: Thu Aug 31, 2006 1:31 pm     Reply with quote
THANKS FOR THE HELP!
