Simple RS232 <--> I2C with very small protocol
Post new topic   Reply to topic    CCS Forum Index -> Code Library
RHA
PostPosted: Tue Apr 25, 2006 5:07 am     Reply with quote
A simple RS232 <--> I2C Communication with very small protocol :
Sending 0x00 from PC to Hardware for Connect-Inquiry gets 0x00 as an answer from the hardware.
Then the first byte high-nibble are the number of bytes to send to I2C and the low-nibble are the numer of bytes to receive from I2C (leave 0 if not needed).
The next bytes are the bytes which would be sended to I2C.
If all Data is collected the hardware sends a 0xe0 to the PC for confirmation.
At next the hardware sends/receives data to/from I2C and puts the received data to the RS232.
After all the hardware sends a 0xee to the PC.
Itīs a simple way to test some I2C-Hardware.
Greets
RHA
#include   <16F876.h>
#define      CLOCK_SPEED   8000000                  //   Hz
#use         delay(clock=CLOCK_SPEED, RESTART_WDT)
#fuses      HS,WDT,NOPROTECT,PUT,NOBROWNOUT,NOLVP,NOCPD,NOWRT
#zero_ram
#byte   TMR0      =   0x01
#byte   PCL      =   0x02
#byte   STATUS   =   0x03
#byte   FSR      =   0x04
#byte   PortA      =   0x05
#byte   PortB      =   0x06
#byte   PortC      =   0x07
#bit   STAT_C   =   STATUS.0
//#bit         =   PortA.0                        //
//#bit         =   PortA.1                        //
//#bit         =   PortA.2                        //
//#bit         =   PortA.3                        //
//#bit         =   PortA.4                        //
//#bit         =   PortA.5                        //
#define   TrisA_Ini   0b11111111                  //   PortA Input/Output
#define   PortA_Ini   0b00000000                  //   PortA Output Init
//#bit         =   PortB.0                        //
//#bit         =   PortB.1                        //
//#bit         =   PortB.2                        //
//#bit         =   PortB.3                        //
//#bit         =   PortB.4                        //
//#bit         =   PortB.5                        //
//#bit   PGC   =   PortB.6                        //
//#bit   PGD   =   PortB.7                        //
#define   TrisB_Ini   0b11111111                  //   PortB Input/Output
#define   PortB_Ini   0b00000000                  //   PortC Output Init
//#bit         =   PortC.0                        //
//#bit         =   PortC.1                        //
//#bit         =   PortC.2                        //
//#bit   SCL   =   PortB.3                        //
//#bit   SDA   =   PortB.4                        //
//#bit         =   PortB.5                        //
//#bit   TX      =   PortC.6                        //
//#bit   RX      =   PortC.7                        //
#define   TrisC_Ini   0b11111111                  //   PortC Input/Output
#define   PortC_Ini   0b00000000                  //   PortC Output Init
//      Variables for generate basic timers       //
int      Pre_01ms;                              //   Prescaler   1ms
int      Pre_50ms;                              //   Prescaler  50ms
int      Pre_01s;                                 //   Prescaler   1s
short      CLK_01ms;                              //   1ms ready
#define   Time_RTCC   0xc8                        //   RTCC     200us   (0.0002 / (((1 / 8MHz) * 4) * 2))
#define   Time_01ms   0x05                        //   Prescaler   1ms   (  5*Time_RTCC)
#define   Time_50ms   0x32                        //   Prescaler  50ms   ( 50*Time_01ms)
#define   Time_01s      0x14                        //   Prescaler   1s   ( 20*Time_50ms)
//      Variables for the RS232-Connection        //
int      RS232_Rx;                              //   Inputbyte
int      RS232_Tx[15];                           //   Outputbytes
int      RS232_TxCount;                           //   Counter for Outputbytes
//      Variablen für die RS232-Schnittstelle      //
int      I2C_Rx;                                 //   Inputbyte
int      I2C_RxCount;                           //   Counter for Inputbytes
int      I2C_Tx[5];                              //   Outputbytes
int      I2C_TxCount;                           //   Counter for Outputbytes
int      I2C_TxPtr;                              //   Pointer for Outputbytes
#use   rs232   (baud=9600,xmit=PIN_C6,rcv=PIN_C7, RESTART_WDT)
#use   i2c      (master,slow,sda=PIN_C4,scl=PIN_C3,force_HW,RESTART_WDT)
#int_rtcc                                       //   Serviceroutine for RTCC
rtcc_isr() {
   TMR0      =   TMR0 - Time_RTCC;                  //   Restart Counter (Overflow would be considered)
   if   (!--Pre_01ms) {                           //   1ms ready ?
      CLK_01ms = True;                           //     Yes  -->   Set Indicator
      Pre_01ms = Time_01ms;                     //            Reset Prescaler
void   send_RS232(int Tx_Byte) {                  //   Send a Byte over RS232
   if (RS232_TxCount < 15) {                     //   Another free byte in buffer ?
      RS232_Tx[RS232_TxCount]   =   Tx_Byte;         //   Write byte in buffer
      ++RS232_TxCount;                           //   Increment Buffer-Counter
      enable_interrupts(INT_TBE);               //   Enable RS232-Transmit
void   I2C_TxRx() {                              //   Send/Receive at I2C
   if   (I2C_TxCount && (I2C_TxCount == I2C_TxPtr)) {   //   Data for sending collected?
      send_RS232(0xe0);                           //   Send confirmation on RS232
      I2C_TxPtr   =   0;                           //   Reset pointer from I2C-Sendingbuffer
      i2c_start();                              //   Start I2C-Communication
      while   (I2C_TxCount) {                     //   Send data on I2C-Bus
         i2c_write(I2C_Tx[I2C_TxPtr]);            //
         --I2C_TxCount;                           //
         ++I2C_TxPtr;                           //
      while   (I2C_RxCount) {                     //   Receive data from I2C-Bus
         I2C_Rx   =   i2c_read();                  //
         send_RS232(I2C_Rx);                     //
         --I2C_RxCount;                           //
      i2c_stop();                                 //   Stop I2C-Communication
      I2C_TxPtr   =   0;                           //   Reset pointer from I2C-Receivebuffer
      send_RS232(0xee);                           //   Send End-Code on RS232
#int_rda                                          //   Serviceroutine for RS232 Receive
rda_isr() {
   RS232_Rx   =   getc();                           //  Read-Out received byte
   if   (!I2C_TxCount) {                           //   Starting protocol (first byte) ?
      if   (RS232_Rx == 0x00) {                     //  Connect-Inquiry ?
         send_RS232(0x00);                        //    Yes  --> Answer
      else {                                    //     No   --> Load counter for protocol
         I2C_RxCount   =   RS232_Rx & 0x0f   ;      //              (Receive-Counter)
         I2C_TxCount   =   swap(RS232_Rx) & 0x0f;   //              (Send-Counter)
   else {                                       //   Collect I2C-Sendingdata ?
      I2C_Tx[I2C_TxPtr]   =   RS232_Rx;            //   Put received byte in I2C-Sendingbuffer
      ++I2C_TxPtr;                              //   Increment pointer on I2C-Sendingbuffer
#int_tbe                                          //   Serviceroutine for RS232 Transmit
tbe_isr() {
   if   (RS232_TxCount != 0) {                     //  Another Byte ?
      putc(RS232_Tx[0]);                        //  Send first byte in buffer
      --RS232_TxCount;                           //   Decrement counter
      memcpy(RS232_Tx,RS232_Tx+1,14);            //   Shift buffer
   else {                                       //   Last byte transmitted ?
      disable_interrupts(INT_TBE);               //   Disable RS232-Transmit
void   timer() {                                 //   Softwaretimer
   if   (CLK_01ms) {                              //   1ms ready ?
      CLK_01ms   =   False;                        //   Reset statusbit
      if   (!--Pre_50ms) {                        //   Decrement Counter for 50ms
         Pre_50ms   =   Time_50ms;                  //   Reset Counter
         if   (!--Pre_01s) {                        //   Decrement Counter for 1s
            Pre_01s   =   Time_01s;               //   Reset Counter
void   init() {                                    //   Initialisation
   PortA   =   PortA_Ini;                           //   Preset Outputs
   PortB   =   PortB_Ini;                           //
   PortC   =   PortC_Ini;                           //
   set_tris_a   (TrisA_Ini);                     //   Set Inputs/Outputs
   set_tris_b   (TrisB_Ini);                     //
   set_tris_c   (TrisC_Ini);                     //
   port_b_pullups(TRUE);                        //   Switch on PortB - Pullups
   setup_adc_ports(NO_ANALOGS);                  //   No Analoginputs
   setup_adc(ADC_CLOCK_DIV_2);                  //
   Pre_01ms = Time_01ms;                        //   Preset Prescaler
//   setup_ccp1(CCP_PWM);                           //   Setup PWM
//   set_pwm1_duty(MOT_DISABLE);                  //
//   out_PWM   =   MOT_DISABLE;                     //
//   setup_timer_3(T3_DISABLED);                  //   Timer3 (not needed)
   setup_timer_2(T2_DISABLED,0,1);               //   Timer2 (not needed)
   setup_timer_1(T1_DISABLED);                  //   Timer1 (not needed)
   setup_counters(RTCC_INTERNAL,RTCC_DIV_2);      //   Timer0 for RTCC
   set_rtcc(-Time_RTCC);                        //   Set RTCC-Initialvalue
   enable_interrupts(INT_RTCC);                  //   Enable RTCC-Interrupt
   enable_interrupts(INT_RDA);                  //   Enable RS232-Receive
   enable_interrupts(GLOBAL);                     //   Enable Interrupts global
void   main() {                                    //   Main loop
   init();                                       //   Initialise Program
   while(true) {
      restart_WDT();                              //   Reset Watchdog
      timer();                                    //   Softwaretimer
      I2C_TxRx();                               //  Send/Receive on I2C
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
microcontrollerless I2C
PostPosted: Tue Apr 25, 2006 2:21 pm     Reply with quote
..and here's a microcontrollerless parallel->I2C interface http://www.maxim-ic.com/appnotes.cfm/appnote_number/980. This one is unidirectional, but it can be made bidiretional.
RHA
PostPosted: Tue Apr 25, 2006 2:43 pm     Reply with quote
Pretty cool,
but i think for most persons itīs easier to work with a standard terminal program and a RS232 connection then with the parallel port.
ciao
RHA
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
