Bill Guest
read_adc modes? |
Posted: Wed Jun 11, 2003 7:23 am |
Hi, Has anyone used the read_adc(); function with the additional modes [ADC_START_ONLY], [ADC_READ_ONLY] or [ADC_START_AND_READ] ??
I can't compile with these modes being utilised. hmm...?
Any help would be appreciated.
___________________________
Original Post ID: 144515157 |
R.J.Hamlett Guest
Re: read_adc modes? |
Posted: Wed Jun 11, 2003 8:01 am |
:=Hi, Has anyone used the read_adc(); function with the additional modes [ADC_START_ONLY], [ADC_READ_ONLY] or [ADC_START_AND_READ] ??
:=I can't compile with these modes being utilised. hmm...?
:=Any help would be appreciated.
What compiler version?.
Have worked OK for me. I have a 'tick' interrupt, where I select the channel on the first 'tick', then on the next loop, trigger a read, without returning the value, with:
read_adc(ADC_START_ONLY);
Then on the third loop, I read the value with:
read_adc(ADC_READ_ONLY);
This way the code in the tick code is kept short. This works with 3.148, and more recently with 3.160.
Original Post ID: 144515159 |
bill Guest
Posted: Wed Jun 11, 2003 6:59 pm |
:=:=Hi, Has anyone used the read_adc(); function with the additional modes [ADC_START_ONLY], [ADC_READ_ONLY] or [ADC_START_AND_READ] ??
:=:=I can't compile with these modes being utilised. hmm...?
:=:=Any help would be appreciated.
:=What compiler version?.
:=Have worked OK for me. I have a 'tick' interrupt, where I select the channel on the first 'tick', then on the next loop, trigger a read, without returning the value, with:
:=read_adc(ADC_START_ONLY);
:=Then on the third loop, I read the value with:
:=read_adc(ADC_READ_ONLY);
:=This way the code in the tick code is kept short. This works with 3.148, and more recently with 3.160.
:=Best Wishes
Thanks,
After looking at the version history it seems these options only appear after v3.148, I have 3.094.
Solved problem by setting ADCON register bit manually.
Original Post ID: 144515163 |
