for (i=0;i<=10;i++) don't work
aaaaamartin
PostPosted: Sun Apr 17, 2005 4:05 pm     Reply with quote
hi,
i tried:
int i,rota, rotb;
main()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
for (i=0;i<=100;++i)
output_high(pin_c1);
delay_ms(30);
output_low (PIN_C1);
The Loop runs one time, and not ten times es expected.
Is this due to optimization ?
Writing more sophisticated things inside the loop makes it run 10 times.
I'm bored.
Please help
Martin
PostPosted: Sun Apr 17, 2005 5:37 pm     Reply with quote
Rule 1: Always post a complete program, including the #fuses and delay statements, etc. Often errors are in the #fuses statement so we can see what processor and clock speed you are using.
Rule 2: When posting code use the 'Code' button. This will help to preserve the layout of your code and makes it much easier for everybody to read.
The problem in your example is very likely because you have no delay after the output_low() function call, so in the next loop iteration the pin is set high again before you are able to detect the pin change.
change to:
  delay_ms(30);
  delay_ms(30);
