ken_o
clear_interrupt |
Posted: Sat Jun 19, 2004 3:18 pm |
I am using the new version em4095.c driver but I still have an older CCS compiler (3.181), and a 16F877A.
My compiler does not have the "clear_interrupt()" built in function.
Question: Does anybody know how I can implement "clear_interrupt(INT_CCP1);" and "clear_interrupt(INT_CCP2);" ?
I have identified four Interrupt Flags (INTF, CCP1IF, TMR1IF, and CCP2IF)but I'm not sure which ones are necessary and what the precise code syntax should be. I have tried some things but nothing helped.
PS: The main symptom is in the CCS driver snippet where my CCP_1 is always zero.
Code: | #INT_CCP1
void isr_ccp1()
int width;
// Toggle between capturing rising and falling edges to meausure width
if(RE_FE_TOGGLE)
setup_ccp1(CCP_CAPTURE_FE);
RE_FE_TOGGLE = 0;
setup_ccp1(CCP_CAPTURE_RE);
RE_FE_TOGGLE = 1;
// Calculate the width
width = CCP_1 - old_clock;
old_clock = CCP_1;
switch(RF_readMode)
// Use to receive manchester formatted data from a transponder
case RF_MANCHESTER_DATA:
if(width > 54) // Check for a phase change
bitValue = ~bitValue; // Invert the save bit value
storeData = TRUE; // Force a bit store
Ken_o |
Posted: Sun Jun 20, 2004 12:43 am |
You are really asking two questions here.
1. How can I implement the new clear_interrupt() function
in my older version of the compiler ?
2. My program doesn't work. Please fix it for me.
It being the weekend, I'm going to answer the first, easy, question.
Here is part of a listing file, which was compiled for the 16F877A
with PCM vs. 3.202.
Code: | .................... clear_interrupt(INT_CCP1);
000F: BCF PIR1.2
.................... clear_interrupt(INT_CCP2);
0010: BCF PIR2.0 |
You can see that in the first line, CCS is clearing the CCP1IF flag in PIR1,
and in the 2nd line, they are clearing CCP2IF in PIR2.
So you could easily do the same thing by declaring those bits
with the CCS #byte and #bit statements. Then set them to 0.
Example:
Code: | #include <16F877A.H>
#use delay(clock = 4000000)
#byte PIR1 = 0x0C
#bit CCP1IF = PIR1.2
#byte PIR2 = 0x0D
#bit CCP2IF = PIR2.0
CCP1IF = 0; // Clear CCP1 interrupt enable flag
CCP2IF = 0; // Clear CCP2 interrupt enable flag
ken_o
Posted: Sun Jun 20, 2004 3:45 pm |
Thanks for the prompt reply. It really did help my weekend efforts!
My clear_interrupt is working now, and your post helped me to advance to the "real" problem.
I believe the real cause was that I did not connect RDY/CLK clock pulse to pin C0 as well as C1.
Thanks again!!
ken_o |
