andyfraser
| Problem with 9-bit Addressing |
Posted: Tue May 04, 2004 4:32 pm |
I am trying to use 9-bit addressing on my RS485 link using a PIC16F877. I cannot get the receive interrupt service routine to be called when set to interrupt on an address but do when I set it to interrupt on data. An extract of the code I am using follows.
As you can see from the code, I set PIN_B5 low then high in the receive ISR. With the initialisation code shown below, I get no activity on B5 however, if I change the line setup_uart( UART_ADDRESS ) to setup_uart( UART_DATA ), I see a pulse for each character on the bus !
Any help would be much appreciated.
Andy
At top of program:
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,enable=RS485_ENABLE,bits=9,long_data,errors,stream=RS485 )
Initialising:
setup_uart( UART_ADDRESS );
setup_uart( TRUE );
output_low( RS485_ENABLE );
// Turn on the serial interrupts
enable_interrupts( INT_RDA );
enable_interrupts( GLOBAL );
Sending:
int8 i;
int8 cs = 0;
// Send address
fputc( (int16)0x100 | g_Packet[ 0 ],RS485 );
// Send the remaining data with the 9th bit clear
for( i = 1 ; i < PACKET_LEN ; i++ )
cs += g_Packet[ i ];
fputc( g_Packet[ i ],RS485 );
// Now send the checksum
fputc( cs,RS485 );
Receiving:
#int_rda
void rx_isr()
int16 b;
output_low( PIN_B5 );
// Get received charcater
b = fgetc( RS485 );
output_high( PIN_B5 );
| Re: Problem with 9-bit Addressing |
Posted: Wed May 05, 2004 3:55 am |
| andyfraser wrote: | Hi,
Andy
At top of program:
Initialising:
setup_uart( TRUE );
Sending:
int8 i;
int8 cs = 0;
// Send address
fputc( cs,RS485 );
Receiving:
#int_rda
void rx_isr()
int16 b;
b = fgetc( RS485 );
I haven't looked at the body of your code, but the obvious problem, is that you are misunderstanding how '9bit' works on the PIC with CCS. Basically, when 9bit mode is enabled, the UART, sends/receives 9bit data, _but_ only 8 bits of this, is sendable/receivable through the main receive data /transmit data register. So 'putc', and 'getc', still only handle 8 bit data. You have to seperate off the 9th bit yourself, and write this bit to the RS232_ERRORS register (bit 7). Look at the example file 'ex_pbusm.c', to see how to do this.
andyfraser
Posted: Wed May 05, 2004 4:49 am |
Ttelmah,
Thanks for the reply but if you look in the body of the code you will see that I don't use putc and getc, i use fputc and fgetc. According to the example code for multi-drop programming (rs485.c) I can send a 16-bit value through fputc. I think this is a feature added recently to the compiler, so I should have explained that I am using version 3.184. Out of interest, I got the code working by manipulating the UART bits directly as shown below.
void SendPacket( void )
int16 hdr;
char cs = 0;
char i;
// Enable transmitter, disable receiver
output_high( RS485_ENABLE );
// Enable 9-bit addressing and set the 9th bit
TX9 = 1;
TX9D = 1;
// Send address byte/digital input bits with the 9th bit set
hdr = 0x100 + g_Packet[ 0 ];
fputc( hdr,RS485 );
// Disable 9-bit addressing and clear the 9th bit
TX9 = 0;
TX9D = 0;
fputc( cs,RS485 );
// Enable receiver, disable transmitter
Andy |
Posted: Wed May 05, 2004 8:53 am |
| andyfraser wrote: | Ttelmah,
int16 hdr;
char cs = 0;
char i;
TX9 = 1;
TX9D = 1;
fputc( hdr,RS485 );
TX9 = 0;
TX9D = 0;
fputc( cs,RS485 );
Andy |
RS485.C, is not a standard CCS example.
The help file, still says that fputc, only takes an 8bit value.
You can write your own 'encapsulated' function like this:
#bit ninth_bit=RS232_ERRORS.7
void send9(int16 val) {
ninth_bit=make8(val,1);
fputc(make8(val,0),RS485);
This will send 9bit data. |
andyfraser
Posted: Wed May 05, 2004 9:04 am |
Ttelmah,
To quote the readme.txt file that came with my version of the compiler :
New options for #UASE RS232:
SAMPLE_EARLY
A getc() normally samples data in the middle of a bit time. This option causes the sample to be at the start of a bit time. May not be used with the UART.
RETURN=pin
For FLOAT_HIGH and MULTI_MASTER this is the pin used to read the signal back. The default for FLOAT_HIGH is the XMIT pin and for MULTI_MASTER the RCV pin.
MULTI_MASTER
Uses the RETURN pin to determine if another master on the bus is transmitting at the same time. If a collision is detected bit 6 is set in RS232_ERRORS and all future PUTC's are ignored until bit 6 is cleared. The signal is checked at the start and end of a bit time. May not be used with the UART.
LONG_DATA
Makes getc() return an int16 and putc accept an int16. This is for 9 bit data formats.
DISABLE_INTS
Will cause interrupts to be disabled when the routines get or put a character. This prevents character distortion for software implemented I/O and prevents interaction between I/O in interrupt handlers and the main program when using the UART.
See RS485.C in the drivers directory for an example RS485 protocol implementation.
However, I could not get this to work correctly and as mentioned in my previous reply, I had to bash the UART registers directly
Andy |
Posted: Wed May 05, 2004 10:58 am |
SAMPLE_EARLY
RETURN=pin
MULTI_MASTER
LONG_DATA
DISABLE_INTS
Andy |
Simple comment. I treat anything that is not at least twenty compiler versions old, as a 'beta'. You now know why. The other comment, is why on earth they will put 'examples', in the 'drivers' directory... :-)
I have the late' compilers, but at present am still treating the 3.148 release as the last eally stable one. The newer version, seem to have introduced a whole 'crop' of bugs at present.
