Odd bootloader behaviour
Linuxbuilders
PostPosted: Tue Aug 16, 2016 3:44 am     Reply with quote
Good day,
I have 2x 18F4620 on the same board, I use the same boot loader for both.
First CPU is happy like a charm. Second is not. I use standard CCS boot loader.
When I turn on enable_interrupts (GLOBAL); then CPU2 stops working.
void systemsetup(VOID)
   setup_wdt (WDT_ON);                                //set watch dog timer
   //output_FLOAT (I2CSCL);
   //output_FLOAT (I2CSDA);
   disable_interrupts (GLOBAL);                       //clear interrupts
   set_timer0 (0);                                    //clear timers
   set_rtcc (0);                                      //clear timers
   setup_timer_0 (RTCC_INTERNAL|RTCC_8_BIT|T0_DIV_1); //set timer 0 parameters
   setup_adc_ports (AN0_TO_AN5|VSS_VDD);              //set AD ports
   setup_adc (ADC_CLOCK_INTERNAL|ADC_CLOCK_DIV_64);   //|ADC_TAD_MUL_2); //ADC_CLOCK_INTERNAL|
   setup_comparator (NC_NC_NC_NC);                    //turn off comparators
   //enable_interrupts (GLOBAL);                        //clear interrupts
   //enable_interrupts (INT_ssp);                       //enable serial i2c
   //enable_interrupts (INT_rda);                       //enable serial port
   //enable_interrupts (INT_RTCC);                      //enable TIMERs
   //i2c_init(TRUE);
// CONFIG TABLES ==================
#include <18F4620.h> //libs from compiler
#device  ADC=10 //analogue to digital converter init specs
#include <ctype.h> //libs from compiler
#include <stddef.h> //libs from compiler
#include <string.h> //libs from compiler
// DEFINE =========================
//#define BUSSPEED           115200
//#define RX_PIN             PIN_C7            //    serial data receive pin
//#define TX_PIN             PIN_C6            //    serial data transmit pin
//#define TX_ON              PIN_C5            //    serial TX on
#define STATUS             PIN_B2            //    status led
//#define I2CSCL             PIN_C3
//#define I2CSDA             PIN_C4
// FUSES ==========================
#FUSES H4
#FUSES MCLR
#FUSES BROWNOUT
#FUSES NODEBUG
#FUSES PROTECT    // code protect
#FUSES CPB        // boot block code protect
#FUSES CPD        // data eeprom code protect
#FUSES NOEBTRB    // boot block table code protect
#FUSES NOEBTR     // table code protect
//#FUSES NOWDT,NOPROTECT,NOLVP
#FUSES WDT4096
#FUSES WDT
#FUSES PUT
#FUSES NOXINST
#use delay (clock=40M)
// SYSTEM =========================
//#use rs232(baud=BUSSPEED,xmit=TX_PIN,rcv=RX_PIN,parity=n,bits=8,stop=1,ENABLE=TX_ON,ERRORS,TIMEOUT=15)
//#use i2c(slave, stream=main, sda=I2CSDA, scl=I2CSCL, address=0xA0, FORCE_HW, SMBUS)
#include "systemsetup.c"
//#include "variables.c"
//#use fixed_io(D_outputs=GOUT1,GOUT2,GOUT3,GOUT4,GOUT5,GOUT6,GOUT7,GOUT8)
//#use fixed_io(A_outputs=BUZZ)
//#use fixed_io(B_outputs=STATUS)
//#use fixed_io(C_outputs=TX_PIN,TX_ON)
//#use fixed_io(E_outputs=POWER,BATTERY)
// MAIN PROGRAM ===================
//#int_rda
//void comm (void)
#include <\BTLD\bootloader.h>
//#zero_ram
   // main program
   systemsetup();
   write_eeprom (0x00,0x00);
   WHILE (true)
      //loop program
      restart_wdt () ;
         //printf("\nOK\r\n");
         output_low (STATUS);
         output_high (STATUS);
So when global are off my bootloader loads app in correctly and runs blinking LED
When I turn on globals then it never leaves the bootloader and after reset is unresponsive.
Ideas? Can it be somehow related to the circuit?
Thnx
Help "d" others and then you shell receive some help from "d" others.
Linuxbuilders
PostPosted: Tue Aug 16, 2016 3:56 am     Reply with quote
to be specific it fails after enable_interrupts (INT_RTCC); is on.
This works:
   //set_timer0 (0);                                    //clear timers
   //set_rtcc (0);                                      //clear timers
   setup_timer_1 (T1_INTERNAL|T1_DIV_BY_1);
   set_timer1 (0);     //clear timers
   //enable_interrupts (INT_TIMER1); //enable TIMERs
   i2c_init(TRUE);
This will not work:
   i2c_init(TRUE);
However the same program will run well when there is no bootloader in use... ideas?
PostPosted: Tue Aug 16, 2016 5:08 am     Reply with quote
ideas..
1) the WDT is enabled, perhaps it's 'timing out', cauisng the failure??
2) every enabled ISR MUST have a handler(code),best to confirm..
3) You should create a program that will TELL you what the 'fialure' is,similar to POST in the PC BIOS.
4) this...
99% of the time is wrong 'internal' is generally used for PICs that do adc while asleep.I don't use that PIC maybe it's 'different' than the rest??
Jay
jeremiah
PostPosted: Tue Aug 16, 2016 8:16 am     Reply with quote
Adding to what temtronic said, you commented out your RDA isr and then enable it anyways. That will cause the chip to continually reset.
PostPosted: Tue Aug 16, 2016 10:44 am     Reply with quote
Unless I am missing something I don't see handlers for SSP, Timer1 or RTCC at all....
Not to mention the order of his program (Fuses, use delay, use rs232 etc) is wrong
Linuxbuilders
PostPosted: Wed Aug 17, 2016 12:52 am     Reply with quote
Of course it is wrong, this is cut program out of larger section just so I can debug what is going on. So please do not be picky about the bits and pieces but focus on the message. I will try to add RTCC section and other relative IRQs and see if it will kick on.
The problem is that the main fully functional program works on the CPU2 if bootloader is not used. If I add bootloader in then the same program does not start up at all. If I load program out of CPU1 which is functional with bootloader then it goes from first kick. So there is something definitely in the RTCC section of CPU2 program which the bootloader does not like. I will try to debug and once I find it I will post.
PostPosted: Wed Aug 17, 2016 1:20 am     Reply with quote
Problem is that when dealing with code, it is the 'bits and pieces' that matter.
The general line here, is that when posting code to show a problem, it should be "a small runnable program, that can be directly compiled, and shows the problem".
If we 'guess' and try to put code together, then we may well be hiding the very problem you want us to solve......
Crying or Very sad
Linuxbuilders
PostPosted: Wed Aug 17, 2016 1:27 am     Reply with quote
Agree, and not.. but I have got it working.
It is CCSC compilator - had to do clean, rebuild the code and it goes. For some odd reason it did the trick but I had to reboot PC. Yesterday 3 hours of fight no luck, today boot up, start CCS, rebuild and without any modifications spot on... very odd...
PostPosted: Wed Aug 17, 2016 5:43 am     Reply with quote
My apologies... Since I am not a mind reader to know what is missing, in the future I will avoid looking at or commenting on your code.
Whatever code you showed us, <or> what is missing, this section is still in the wrong order regardless.
Fuses need to come right after the processor definition, then your #device line, then your #use lines, then your #includes and variables.
#FUSES H4
#FUSES MCLR
#FUSES BROWNOUT
#FUSES NODEBUG
#FUSES WDT4096
#FUSES WDT
#FUSES PUT
#FUSES NOXINST
Linuxbuilders
PostPosted: Thu Aug 18, 2016 12:49 am     Reply with quote
Thnx, It is not my intention to upset everybody but please understand that it is hard to past program containing large pieces built out of many lines. ...many lines...
Thank you for directions on the order of the program. It is very good tip. I wish the compiler would throw indication on incorrect order of the statements.
I was more after experience in the compilation process which could affect the compilation when bootloader is added. Obviously the order of the statements may having something to do with it. So I will correct it and we see how it goes.
