any idea how to get work HOPE RF 12B module with PIC ?
artohautala
PostPosted: Thu Aug 27, 2015 5:57 am     Reply with quote
Hello Everybody,
I'm trying to develope RF link between two PIC controllers but no success...
So I have transmitter and receiver but they do not communicate together ...
My module is HOPE RF 12B...
Sure I have read all possible datasheets and tutorials but no success !
I followed this example demo:
https://www.sparkfun.com/datasheets/Wireless/General/RF12B_code.pdf
Is here anybody who made those modules really work in practice ?
I'll be happy if someone can help me ! javascript:emoticon('Very Happy')
(The transmitter blinks led OK but it is not sure if it is still programmed OK
The receiver led blinks randomly .. and not very often it should blink in sync to transmitter ...)
have fun
-artohautala-
PostPosted: Thu Aug 27, 2015 6:49 am     Reply with quote
Please post a link to the RF module you are using. Hopefully it'll say whether it's 5 volt or 3 volt. The link you supplied is a 2006 programming datasheet without physical specs, also you need antenna,power supply details etc.
As well show us your code. You could have a simple error in coding.
The more information you supply, the faster and better we can help.
Jay
PostPosted: Thu Aug 27, 2015 6:56 am     Reply with quote
Here's a link from googling 'hope rf12b ccs code'
http://forum.jeelabs.net/node/91.html
About 1/2 way down there is working(well he says it is) code for a 16F690(?) PIC using CCS code.
I'd download, compile and confirm it has no errors THEN copy source to 'my_filename.c' files, then alter as required for your PIC type, xtal, etc.
Do NOT alter the original source files or you'll be sorry !!
Jay
Porter Oswin
PostPosted: Thu Aug 27, 2015 7:10 am     Reply with quote
Jay
Well said, I hope that is understandable.
artohautala
PostPosted: Thu Aug 27, 2015 8:57 am     Reply with quote
Jay
Sorry what mean this :
here is my tx code:
#include <16F73.h>
#fuses HS,NOWDT,PUT
#use delay(clock = 10000000)
#define SDI             PIN_B5
#define SDO             PIN_B4
#define SCK             PIN_B3
#define nSEL            PIN_B2
#define LED             PIN_A0
void Init_RF12(void);            //init tx
void WriteCmd(int16 CMD);
void Write0(void);
void Write1(void);
void WriteFSKbyte(int16 data);
void main(void){
         int16 ChkSum;
         int8 i = TRUE;                   //to avoid warning while(1)...
         delay_ms(1000);                  //1s delay for startup
         for( i = 0; i < 5; ++i){         //blink led 5 times for test
            output_high(LED);
            output_low(LED);
         Init_RF12();
         i = TRUE;
         while(i){
            ChkSum = 0;
            WriteCMD(0x8228);         //open PA
            delay_us(4);
            WriteCMD(0x8238);
            delay_us(2);
            WriteFSKbyte(0xAA);
            WriteFSKbyte(0xAA);
            WriteFSKbyte(0xAA);
            WriteFSKbyte(0x2D);
            WriteFSKbyte(0xD4);
            WriteFSKbyte(0x30);         //data 0
            ChkSum += 0x30;
            WriteFSKbyte(0x31);         //data 1
            ChkSum += 0x31;
            WriteFSKbyte(0x32);
            ChkSum += 0x32;
            WriteFSKbyte(0x33);
            ChkSum += 0x33;
            WriteFSKbyte(0x34);
            ChkSum += 0x34;
            WriteFSKbyte(0x35);
            ChkSum += 0x35;
            WriteFSKbyte(0x36);
            ChkSum += 0x36;
            WriteFSKbyte(0x37);
            ChkSum += 0x37;
            WriteFSKbyte(0x38);
            ChkSum += 0x38;
            WriteFSKbyte(0x39);
            ChkSum += 0x39;
            WriteFSKbyte(0x3A);
            ChkSum += 0x3A;
            WriteFSKbyte(0x3B);
            ChkSum += 0x3B;
            WriteFSKbyte(0x3C);
            ChkSum += 0x3C;
            WriteFSKbyte(0x3D);
            ChkSum += 0x3D;
            WriteFSKbyte(0x3E);
            ChkSum += 0x3E;
            WriteFSKbyte(0x3F);        //data 15
            ChkSum += 0x3F;
            ChkSum &= 0x0FF;
            WriteFSKbyte(ChkSum);
            WriteFSKbyte(0xAA);
            WriteCMD(0x8208);         //close PA
            WriteCMD(0x8200);         //receive END , EHKÄ SEND END ?!   ?????  S.14
            //blink test led:
            output_high(LED);
            output_low(LED);
void Init_RF12(void){            //init lähetin !
      output_low(LED);
      output_high(nSEL);
      output_high(SDI);
      output_low(SCK);
      //configuration setting command...80 = command
      WriteCmd(0x80D8);
      //turn on crystal !PA      power management command
      WriteCmd(0x8208);
      /* frequence setting command ... taajuus 868.650 Mhz
      868 band: Fc = 860 Mhz + F * 0.0050 Mhz , F = (Fc - 860 Mhz) / 0.0050 Mhz = 1730
      = 0x6C2
      WriteCmd(0xA640);
      /* data rate command:
         kts. printti RFM12 tutorial-part3a s.9
      WriteCmd(0xC647);  //bitrate 4800
      WriteCmd(0xCC77);  //PLL setting command, default value look at page 7 or 0xCC76?
      WriteCmd(0x94A0);  //VDI, FAST, 134 kHZ,0dBm -103 dBm (receiver control command ?)
      WriteCmd(0xC2AC);  //data filter command
      WriteCmd(0xCA80);  //FIFO and reset mode command
      WriteCmd(0xCA83);  //FIFO8, SYNC
      WriteCmd(0xC49B);  //AFC command
      WriteCmd(0x9850);  //!mp,9810 = 30 kHz, MAX OUT
      WriteCmd(0xE000);  //WAKEUP TIMER , NOT USED
      WriteCmd(0xC80E);  //low duty cycle command, NOT USED
      WriteCmd(0xC000);  //1,0 Mhz, 2.2 V
void WriteCmd(int16 CMD){
      int16 n = 16;
      output_low(SCK);
      output_low(nSEL);
      while(n --){
         if(CMD & 0x8000)
            Write1();
               Write0();
            CMD = CMD << 1;
      output_low(SCK);
      output_high(nSEL);
void Write0(void){
      output_low(SCK);
      delay_us(2);
      output_low(SDI);
      delay_us(15);
      output_high(SCK);
      delay_us(2);
void Write1(void){
      output_low(SCK);
      delay_us(2);
      output_high(SDI);
     delay_us(15);
      output_high(SCK);
      delay_us(2);
void WriteFSKbyte(int16 DATA){
         int8 RGIT = 0;
         int16 temp = 0xB800;
         temp |= DATA;
Loop:
         output_low(SCK);
         output_low(nSEL);
         output_low(SDI);
         output_high(SCK);
            if(input(SDO) )               //polling SDO
            RGIT = 1;
            RGIT = 0;
         output_low(SCK);
         output_high(SDI);
         output_high(nSEL);
            if(RGIT == 0)
            goto loop;
            else{
            RGIT = 0;
            WriteCMD(temp);
and here is my rx code:
#include <16F73.h>
#fuses HS,NOWDT,PUT
#define SDI             PIN_B5
#define SDO             PIN_B4
#define SCK             PIN_B3
#define nSEL            PIN_B2
#define nIRQ            PIN_B1
#define LED             PIN_A0
void Init_RF12_RX(void);
void Write0(void);
void Write1(void);
int8 RF12_RDFIFO(void);
int16 RX_RFBUF[19];
void main(void){
         int16 ChkSum;
         int1 k = TRUE;
         int8 i = 0;    int8 j = 0;
         Init_RF12_RX();
         while(k){
              while(!input(nIRQ)){
                 RX_RFBUF[i++] = RF12_RDFIFO();
                    if(i == 17){
                       i = 0;
                       WriteCmd(0xCA80);         // ??
                       WriteCmd(0xCA83);         // reset FIFO and read to receive nect Byte
                       ChkSum = 0;
                         for(j = 0; j < 16; j++)
                          ChkSum += RX_RFBUF[j];   //add 0x30 --------- 0x3F ????????
                       ChkSum &= 0x0FF;
                    if( ChkSum == RX_RFBUF[16]){
                     output_high(LED);
                     delay_ms(10);
                     output_low(LED);
                     delay_ms(10);
void Init_RF12_RX(void){
      output_low(LED);
      output_high(nSEL);
      output_high(SDI);
      output_low(SCK);
      output_low(SDO);
      WriteCmd(0x80D8);      //433 Mhz band
      WriteCmd(0x82D8);      //enable receive !PA
      WriteCmd(0xA640);
      WriteCmd(0xCC77);  // PLL setting command s. 7 RF12B V1.2 printti... 0xCC77 tai 0xCC76 ????
      WriteCmd(0xC49B);
      WriteCmd(0xC800);  //low duty command , NOT USED
      WriteCmd(0xC000);  //1.0 Mhz, 2,2 V
      int16 n = 16;
      output_low(SCK);
      output_low(nSEL);
      while(n --){
         if(CMD & 0x8000)
            Write1();
               Write0();
            CMD = CMD << 1;
      output_low(SCK);
      output_high(nSEL);
void Write0(void){
      output_low(SCK);
      delay_us(2);
      output_low(SDI);
      delay_us(15);
      output_high(SCK);
      delay_us(2);
void Write1(void){
      output_low(SCK);
      delay_us(2);
      output_high(SDI);
     delay_us(15);
      output_high(SCK);
      delay_us(2);
         int16 RGIT = 0;
         temp |= DATA;
Loop:
         output_low(SCK);
         output_low(nSEL);
         output_low(SDI);
         output_high(SCK);
            RGIT = 1;
            RGIT = 0;
         output_low(SCK);
         output_high(SDI);
         output_high(nSEL);
            if(RGIT == 0)
            goto loop;
            else{
            RGIT = 0;
            WriteCMD(temp);
 int8 RF12_RDFIFO(void){
       int8 i,Result;
         output_low(SCK);
         output_low(SDI);
         output_low(nSEL);
            for(i = 0; i < 16; i++){      //skip status Bits
              output_high(SCK);
              delay_us(2);                          //NOPs
              output_low(SCK);
              delay_us(2);                          //NOPs
         Result = 0;
            for(i = 0; i < 8; i++){      //read FIFO data Byte
               Result = Result << 1;
                  if( input(SDO))
                  Result |= 1;
               output_high(SCK);
               delay_us(2);                          //NOPs
               output_low(SCK);
               delay_us(2);
         output_high(nSEL);
         return result;
PostPosted: Thu Aug 27, 2015 1:30 pm     Reply with quote
re:
It means to always make a COPY of the original program and edit (alter) the COPY not the original program.
Jay
artohautala
PostPosted: Thu Sep 10, 2015 5:41 am     Reply with quote
Jay
I can not to make it work ... where I can find this function : rf12_xfer(0xCE00 | group) ?
I'm not using standard SPI pins...
my pins are :
#include <16F73.h>
#fuses HS,NOWDT,PUT
#define SDI             PIN_B5
#define SDO             PIN_B4
#define SCK             PIN_B3
#define nSEL            PIN_B2
#define nIRQ            PIN_B1
so is it posibble to use those pins for spi communication or do I have to change my hardware?
I'll be very pleased if you can help me
Razz
best regards
-arto-
