PIC24FV16KM204 regarding RA6
jaikumar
PostPosted: Thu Aug 08, 2013 12:50 am     Reply with quote
Hi All,
Compiler 5.010.
In the device file: 24FV16KM204.h, the data for PIN_A6 was missing.
Is there a reason why ccs left that port pin(RA6).
I added the line as below.
But the output would not toggle for PIN_A6.
Could someone please help.
Thanks and Regards,
Jai.
24FV16KM204.h
#define PIN_A0  5648
#define PIN_A1  5649
#define PIN_A2  5650
#define PIN_A3  5651
#define PIN_A4  5652
#define PIN_A5  5653
#define PIN_A6  5654 <--- this was added by me.
#define PIN_A7  5655
#define PIN_A8  5656
#define PIN_A9  5657
#define PIN_A10  5658
#define PIN_A11  5659
main.h
#include <H:\Program Files\PICC\Projects\PIC24_proj1\24FV16KM204.h>
#FUSES HS
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#device ICSP=1
#use delay(crystal=20000000)
#define LED1 PIN_A6
#define LED2 PIN_A7
#define DELAY 1000
main.c
#include <main.h>
   setup_adc(ADC_OFF);
   setup_comparator(NC_NC,NC_NC);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   //Example blinking LED program
   while(true)
      output_low(LED1);
      output_low(LED2);
      delay_ms(DELAY);
      output_high(LED1);
      output_high(LED2);
      delay_ms(DELAY);
RF_Developer
PostPosted: Thu Aug 08, 2013 1:29 am     Reply with quote
If you read the datasheet, you'll see that on the many versions of this processor family that pin is used for Vddcore/Vcap instead of RA6. In other words RA6 may not be usable on that processor.
jaikumar
PostPosted: Thu Aug 08, 2013 1:41 am     Reply with quote
Thank you. I just read the datasheet.
Sorry, Next time will read datasheet before posting.
regards,
jai.
